8th November 2016, 08:26 PM
Won't start
Hi, thanks for the add, I have a 2002 3lt Patrol that has a brand new battery but will not turn over fast enough to start any ideas? Thx
8th November 2016 08:26 PM
8th November 2016, 08:32 PM
Moderator
Has it just started doing it? Has it been getting worse or all of a sudden?
If it turned over it should start. The NATS (Nissan Anit THeft System) cuts off the fuel solenoid on teh back of the pump and it could be your problem.
Check out my Toy -->
Rogue Dung Beetle
8th November 2016, 08:34 PM
Welcome aboard Spook58 !
I'm sure someone with descent lecky advice will be along shortly to assist mate. My only guess would be solenoid thingy issues off your starter motor mate?
8th November 2016, 08:40 PM
Moderator
@Yendor might be able to guide you mate, I have experienced this on a TD42 but not a ZD30. Search the forum for NATS and or Immobiliser fault and you will find some info. When did you fit the battery?
Rogue Dung Beetle
8th November 2016, 08:49 PM
The 747
Does it turn over slowly?
9th November 2016, 08:37 AM
Welcome to the forum mate.
9th November 2016, 09:13 PM
10th November 2016, 09:53 AM
Hey mate, welcome to the forum.
10th November 2016, 10:14 AM
G'day and welcome mate. If its turning over slowly, it may be the starter nmotor atself or corrosion on the 12v main lead or terminal causing high resistance. After trying a couple of time, check the terminals at the starter motor end and the battery end and see if they are hot. that would indicate a high resistance joint.
