25th September 2016, 03:40 PM
The Following 4 Users Say Thank You to Skitzyrex For This Useful Post:
Bigcol (25th September 2016), Clunk (2nd October 2016), MudRunnerTD (25th September 2016), NissanGQ4.2 (25th September 2016)
25th September 2016 03:40 PM
25th September 2016, 07:48 PM
Micks 4.8 GU
Some other things I've had made or just bought.
Black widow shelf with checker plate and led strip on the back door.
![](http://www.nissanpatrol.com.au/forums/images/imported/2016/09/228.jpg)
![](http://www.nissanpatrol.com.au/forums/images/imported/2016/09/229.jpg)
A shelf my dad welded up the frame and I just got old security mesh from a salvage yard. Can utilize the space above the fridge now and just added some thin rubber to help things not slide off.
Also have another led strip on the cargo barrier which helps light everything up.
2007 GU ST-S 4.8 Patrol.
40mm heavy duty springs, Dual batteries,
140 ltr fuel tank,Custom 60ltr water tank, draws, cargo barrier, bull bar, IPF spotties, UHF.
The Following 3 Users Say Thank You to Skitzyrex For This Useful Post:
Bigcol (25th September 2016), Clunk (2nd October 2016), gubigfish (31st October 2016)
25th September 2016, 08:13 PM
I've installed both rear and side awnings, I just find the rear one handy for coverage when using the rear shelf or just a bit of shade on the pit stops.
![](http://www.nissanpatrol.com.au/forums/images/imported/2016/09/231.jpg)
Had an ironman compressor and wanted to save draw space so took the handle off and put in the unused space beside the draw. It has a pressure switch so turns off if the pressure gets too high.
![](http://www.nissanpatrol.com.au/forums/images/imported/2016/09/232.jpg)
I fitted a whip am/fm aerial and disconnected the electric one as it was only a matter of time before that got snapped.
The Following 2 Users Say Thank You to Skitzyrex For This Useful Post:
25th September 2016, 08:43 PM
abw (2nd October 2016), Bigcol (25th September 2016), Clunk (2nd October 2016), Touses (26th September 2016)
2nd October 2016, 06:56 PM
Going away next weekend and still haven't had time to finish my wooden battery box. So I decided to move the arc one across to the other side and extend all the wiring, a job that that had to be done anyway.
Freed up a heap of useable space.
The Following User Says Thank You to Skitzyrex For This Useful Post:
3rd October 2016, 01:39 PM
Looks nice! I hope you enjoy the new mods.
22nd October 2016, 09:22 PM
Micks 4.8 GU
Almost finished my battery box.
Changed the front switch panel to galv sheet and covered it all in carpet.
![](http://www.nissanpatrol.com.au/forums/images/imported/2016/10/240.jpg)
![](http://www.nissanpatrol.com.au/forums/images/imported/2016/10/241.jpg)
![](http://www.nissanpatrol.com.au/forums/images/imported/2016/10/242.jpg)
Not real happy with my Ali angle I did but it will do.
![](http://www.nissanpatrol.com.au/forums/images/imported/2016/10/243.jpg)
And organized chaos in the back of the car. Wiring up interior and exterior camping lights, compressor, and reverse lights
30th October 2016, 10:47 PM
#8
More additions. Pretty much done.
![](http://www.nissanpatrol.com.au/forums/images/imported/2016/10/303.jpg)
And an Engel plug at the back.
Clunk (31st October 2016), gubigfish (31st October 2016)
7th January 2017, 02:05 PM
#9
those box designs have given me some good ideas for mine mate how do you go for heat inside the box?
7th January 2017, 03:39 PM
#10
Ryanbaxwar
No problem mate. I've left the whole right hand side of the box open for that reason.
