Page 708 of 1056 FirstFirst ... 208608658698706707708709710718758808 ... LastLast
Results 7,071 to 7,080 of 10559
  1. #7071
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Had the alternator replaced.... for anyone with a CRD make sure you're sitting down when you hear the price of genuine replacement alternator!!!
    Jun 2011
    Darwin NT
    sooooo, well EEZZEE is no longer with us but have Frosty and I kitted it out with some new boots Pirrelli Scorpians MTR 285/75/17... they are pretty cool and at the right price....I know its a jeep but love being part of the patrol family. heres some pics
  4. The Following User Says Thank You to Timmo For This Useful Post:
    Woof (20th October 2016)
  5. #7073
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    what a prick fitting that was. Might have to adjust the intercooler position very slightly and then get some rubber / foam to seal it. Might look at a fan for underneath the cooler too.
  6. #7074
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Pardon the dumb question if I've missed anything as I haven't been on here much lately , @sooty_10 did you fit a bigger scoop ? I want to do that to mine but still deciding which 1 ...... I bought another standard scoop to fit next to the original 1 but the original is not quite left of centre so it would be a big job to trim the side of each to get them side by side & centred - if that makes sense .
  7. #7075
    Bendigo
    7 Post(s)
    Yeah mate new scoop. Fitted a Colorado scoop on. Bit of grinder work to make sure it fits. The hardest bit and most time consuming part was lining it all up and double checking before the first grinder cut. First cut done and it was just keep going.
  8. #7076
    Beginner Andy76's Avatar
    Karratha (north west WA)
    Fitted 22" lightbar and domin8r winch thanks to the great info from people on here made the job easy
  9. #7077
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Thanks@sooty_10 what are the measurements of that ? I've looked at a few others but they're either wide enough but not deep enough or visa versa , & did you buy that new ?
  10. #7078
    Bendigo
    7 Post(s)
    Not sure on measurements, I have a 300 x 640mm intercooler w/ end tanks and it is wider than the intercooler. It is a little bit shorter than the 300mm core but I may consider options on trimming it or moving intercooler. I bought it off gumtree second hand with a bonnet. I got the bloke to cut it out with some bonnet left and brought it back as checked in luggage from the sunny coast. I have the bonnet skin I traced and used as a template for lining it up.
  11. #7079
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    Nothing big but got the roof rack fitted. Finally can fit our stuff to go camping. IMG_1804.JPG
  12. #7080
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Yeah no dramas @sooty_10 , I assume it covered the hole from the original scoop ?
