Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Winches
    Jul 2015
    I have one of the USA branded
    Well know branded winch on my patrol
    Retail is over $1500
    What a waste of time and money
    Never again
    I will go with the cheaper models in future and save my money
  2. #22
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Yeah No Dramas Kallen thanks again 👍🏼
  3. The Following User Says Thank You to Sprock For This Useful Post:
    BigRAWesty (21st July 2016)
  4. #23
    Advanced Dirtydog16's Avatar
    Feb 2012
    Armstrong Creek, Qld, Australia
    I read a while ago (a number of years I think) that one batch of aldi winches were re-branded iron-man winches.
    Depends who aldi get a good deal from.
    Check it out on the net and some of the other forums have discussions on them.
  5. #24
    Jul 2015
    Camden NSW
    6 Post(s)
    I ran two Aldi winches on two Prado's over ten years. Never had an issue with either one. If the Warn ever died on my Patrol I would not hesitate replacing it with an Aldi unit. I think the most important thing with the cheaper winches is to pull them apart when new, replace the grease with quality stuff, and apply a bead of sealant on all gaskets/seals.
  6. #25
    Theres a mob at the back of Tullamarine Park drive that see 12,00lb winches for about $400
    Place is called Radum they import chinese equipment like pipe benders,, 12t press'sPlenty of gear
    thats for sure
  7. #26
    Quote Originally Posted by Dirtydog16 View Post
    Check it out on the net and some if the other forums have discussions on them.
    Yep, I've heard the same, might have been around 2010ish.
    Sent from my XT1068 using Tapatalk
  8. #27
    Beginner Andy76's Avatar
    Karratha (north west WA)
    I have just purchased the domin8er just need to figure how to install on a factory bullbar.
  9. #28
    Just wondering if anyone has the new domin8r x winch and if so can you rotate the gear box i read some where that you cant bit just thought id ask the question.
    Cheers in advance
  10. #29
    Expert Skitzyrex's Avatar
    Jul 2013
    Quote Originally Posted by Andy76 View Post
    Cheers in advance
    Not sure how new the one you're talking about is, however I bought one over a year ago and you could rotate them. I did a write up on installing into a std Nissan winch bar. You'll also find a thread on installing into an alloy bar using a winch cradle if you have a search.
    2007 GU ST-S 4.8 Patrol.
    40mm heavy duty springs, Dual batteries,
    140 ltr fuel tank,Custom 60ltr water tank, draws, cargo barrier, bull bar, IPF spotties, UHF.
  11. #30
    Only just had it delivered ill check out your post and take it from there.
