Page 21 of 95 FirstFirst ... 1920212223 ... LastLast
Results 201 to 210 of 941
  1. #201
    469 Post(s)
    BigRAWesty (18th September 2016)
  3. #202
    469 Post(s)
  4. The Following 4 Users Say Thank You to mudski For This Useful Post:
    BigRAWesty (20th September 2016), Hodge (19th September 2016), jay see (19th September 2016), MB (20th September 2016)
  5. #203
    If you're after bit more room couldn't you get another awning side and attach it to the front..
    Sent from my XT1068 using Tapatalk
  6. #204
    477 Post(s)
    If you're after bit more room couldn't you get another awning side and attach it to the front.. Sent from my XT1068 using Tapatalk
    You mean like an 'Oz-Tent' Jaysee :-) Luv ya Mr Mark & Family, just stirring :-)
  7. The Following User Says Thank You to MB For This Useful Post:
    mudski (20th September 2016)
  8. #205
    Got to test out my ARB side awning and two awning sides with two double swags under it. Took me and the missus a bit to work out the best way to fit both swags under it for the first time setting it up, but it worked out good.
    Attachment 69107
    That drop slide is a god send too. So much easier to access the fridge. Money well spent in my opinion.
    Is it just you and the missus in 2 seperate double swags
    469 Post(s)
  10. #207
    469 Post(s)
  11. #208
    469 Post(s)
  12. The Following 3 Users Say Thank You to mudski For This Useful Post:
    BigRAWesty (24th October 2016), Clunk (24th October 2016), jay see (23rd October 2016)
  13. #209
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Looks good mark, nice and neat. Did you build your own cage, or is that one of the msa ones?
  14. #210
    469 Post(s)
    Nah the MSA cage is nearly $500. I went to two local steel mobs for the mesh and they would only sell it in massive sections. Trying to declutter the garage it didnt want that so i got it from Dunn and Watson. It wasnt the right size, either too big or too small so i went the too big option and made it fit. The cage is mounted to the slide itself, not to the drawers. i had to buy longer bolts for the slide and change the slide bolts, then i could space out the side sections of the cage. Then make it up as i went to fit the top section. weird thing is the bolts that came with the cage couldn't be used for anything. Even too small too attached the top and back sections of the cage. After fitting i went for a drive and the rattle from the cage against the barrier was annoying. So a few zip ties later and is all quiet. Lol.
  15. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Bacho86 (24th October 2016), BigRAWesty (24th October 2016)
