BigRAWesty (18th September 2016)
BigRAWesty (20th September 2016), Hodge (19th September 2016), jay see (19th September 2016), MB (20th September 2016)
If you're after bit more room couldn't you get another awning side and attach it to the front..
Sent from my XT1068 using Tapatalk
mudski (20th September 2016)
BigRAWesty (24th October 2016), Clunk (24th October 2016), jay see (23rd October 2016)
Looks good mark, nice and neat. Did you build your own cage, or is that one of the msa ones?
Nah the MSA cage is nearly $500. I went to two local steel mobs for the mesh and they would only sell it in massive sections. Trying to declutter the garage it didnt want that so i got it from Dunn and Watson. It wasnt the right size, either too big or too small so i went the too big option and made it fit. The cage is mounted to the slide itself, not to the drawers. i had to buy longer bolts for the slide and change the slide bolts, then i could space out the side sections of the cage. Then make it up as i went to fit the top section. weird thing is the bolts that came with the cage couldn't be used for anything. Even too small too attached the top and back sections of the cage. After fitting i went for a drive and the rattle from the cage against the barrier was annoying. So a few zip ties later and is all quiet. Lol.
Bacho86 (24th October 2016), BigRAWesty (24th October 2016)
