Page 700 of 1056 FirstFirst ... 200600650690698699700701702710750800 ... LastLast
Results 6,991 to 7,000 of 10559
  1. #6991
    Im yet to see how 10mm extra diameter,,really 5mm will improve the stopping power
    IMHO I dont think a 5mm bigger rotor [316mm] will stop any better than the 306mm rotor
    The more you increase your diameter, the surface area of the rotor increases exponentially. It's a pretty big deal.
    mudski (14th September 2016)
    @Cuppa if you want your brakes to work properly
    [better] then book it in at "Hopper Stoppers" in
    Hoppers Crossing, they can make anything stop
    on a dime, Dont have their number but would be easy to find
    @Winnie how much of that extra 5mm is being used??,
    I agree with @Kimbo63 the calipher upgrade is doing all the work
  5. #6993
    465 Post(s)
    Then why do people "up grade" to TB48 rotors looking for more stopping power.
    Just maybe mr nissan thought that people would buy the biggest engine for towing and gave it the larger diameter rotors and calipers.
    finished crying lol
    You need to actually drive a Patrol that has done the conversion to see for yourself...
    Its not just the larger rotor. The master cylinder and caliper pistons are larger on the 4.8's. I was going through my crash cam recordings last night, as it was recording whilst I was getting the brake test done by the engineer. A comment came up over the cam from the driver saying how good this(my) Patrol stops. And they are very surprised as they don't often get good brake results from a Patrol.
    Doing the 4.8 brakes and braided brake lines is by far one of the best things I have done to the Patrol.
    AND the test was done with Genuine Nissan Pads....
  6. The Following 3 Users Say Thank You to mudski For This Useful Post:
    Clunk (14th September 2016), Robo (15th September 2016), threedogs (14th September 2016)
  7. #6994
    465 Post(s)
    .... (Anyone know if there are any performance shoes available for the rear drums?).
    Rear disc conversion Ian. Although less surface contact area using disc over drum, but you have more clamping power on a disc and less the chance of brake fade due to heat.
  8. #6995
    And less chance of having a shoe stuck inside the drum.GRrrrrrrr
    I converted my RV troopy to disc rear end ,best mod ever.
  9. #6996
    Western suburbs of Melbourne
    11 Post(s)
    hope it helps
  10. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
  11. #6997
    All I know is alot of the winch challenge Patrols went there to enhance their brakes'
  12. #6998
    Get rid of the patrols bias valve and put an adjustable bias valve in. Then you will see a notable improvement.
  13. #6999
    465 Post(s)
    The OEM valve is Adjustable to though.... How adjustable I'm not sure.
  14. The Following User Says Thank You to mudski For This Useful Post:
    MEGOMONSTER (15th September 2016)
  15. #7000
    Yeah but is still flawed in its operation. There is improvements to be had if you want to gain a little more.
  16. The Following User Says Thank You to nissannewby For This Useful Post:
