Page 9 of 15 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 150
Thread: mudnut's 'Old Trol' build thread.
  1. #81
    The Coil Tower strengthening kit arrived today. A tough, looking bit of kit. Gotta go and speak to a mate about using his hoist and a bit of muscle to install it.
  2. The Following User Says Thank You to mudnut For This Useful Post:
    MB (2nd September 2016)
    Patrol Guru
    Jul 2014
    6 Post(s)
    To help water proofing the engine, along with the dipstick clip, the timing belt cover hose nipple and the air breathers, I have also raised the Thermal Vacuum Valve inlet and added a filter to it.
    Can you waterproof my engine
  5. #83
    Sounds like a road trip is on the cards. Gotta get hold of an air horn pump so I can pressurise the timing belt cover and distributor. The Fuel Miser dissy cap already has a moulded in nipple so that will be easy.
  6. #84
    Patrol Guru
    Jul 2014
    6 Post(s)
    I've already got one plumbed up to the dizzy. Never used it though, always been worried about the dizzy being too well sealed and blowing the plug leads off haha. Also, I need to mount the air horn somewhere better, back of the engine bay probably won't be much good to me. Just a shame they're so noisy.
  7. The Following User Says Thank You to Throbbinhood For This Useful Post:
    mudnut (5th October 2016)
  8. #85
    here a pic of one already welded in hope it helps
  9. #86
    Quote Originally Posted by Throbbinhood View Post
    I am thinking of installing it under the dash, or maybe using the ARB compressor with a regulator turned right down. I have extended the compressor inlet up to to a quarter panel trim so it wont suck water.
  10. #87
    Thanks, TD. I got the bolt on type from Superior Engineering.
  11. #88
    What a mongrel job. The first hurdle has fitting the brace to the top of the coil tower. The LH tower was warped and the holes didn't line up so I had to drill a few out.
    The arm that attaches to the rear cross member uses a U bolt. I recommend trimming the threads a bit before fitting it as trying to do the nuts up takes bloody ages.
    The brace arm has bent while trying to tighten the adjusting bolt. I don't know if that will cause it to flex or not.
    The RH tower has a few small bolts holding the brake hoses and the tabs holding these were broken but some multigrips clamped them, just!
    As the tower was bent up I was able to force the brace in without damaging the brake and fuel lines, by the barest of margins.
    The rear arm is gonna be almost impossible to tighten unless I remove the fuel hoses.
    I thought I could fit the braces in a couple of hours, but It will be a 12 hour job. The main criticism is that the adjusting bolts supplied are too short by at least 15mm..
  12. #89
    A 12 hour job that is gunna end up being an 18 hour job. I straightened the LH side by undoing all the bolts on the arm and using a hefty G clamp and 12mm thick piece of steel across the bent piece. With the clamp in place, I set the adjustment and torqued the three bolts FT then removed the clamp.
    I tackled the RH side and found it easier to tighten the U bolt nuts up, with the arm dangling down then lifting it up and bolting it to the brace, which meant I only had to torque U bolt nuts.
    After I had positioned the springs and the supplied urethane spacers, I struggled to get the bastards to stay in position. Even with Mrs mudsane operating the trolley jack, I found it extremely hard to get the springs to sit over the urethane. I eventually gave up, removed the offending bits and used a hoof trimmer to cut a bevel on the rubber. After a few goes I finally got the springs in and the shockers and panhard on.
    I decided to check everything and noticed that the two centre bolts of the brace were long enough to interfere with the brake and fuel lines.
    I had to drop everything, remove the RH spring and centre bolts. I cut 8-9mm off the bolts, replaced them and fitted the springs and suspension again.
  13. The Following User Says Thank You to mudnut For This Useful Post:
    timbar (12th September 2016)
  14. #90
    Legendary timbar's Avatar
    Feb 2011
    perth
    Sounds like a hard days work !!
    1989 GQ LPG / PET TB42 LWB WAGON 4'LIFT 33's
    WELCOME TO THE MUD PITT WE DRIVE NISSAN PATROLS
  15. The Following User Says Thank You to timbar For This Useful Post:
