6th September 2016, 08:40 PM
Travelling Podologist
Interesting read - doesn't mince words about ZD30's
http://www.outbacktravelaustralia.co...ddles-may-2016
"In most cases there isn’t an issue with this system, but there have been some spectacular failures: most notably Nissan’s horrible ZD30 three-litre diesel that will be consigned to history when the Patrol departs the scene in late 2016.
The Following 9 Users Say Thank You to Cuppa For This Useful Post:
Clunk (6th September 2016), lagoonboy (15th September 2016), mudnut (6th September 2016), MudRunnerTD (6th September 2016), Plasnart (6th September 2016), the godfather (8th September 2016), Touses (7th September 2016), VK2FMIA (7th September 2016), Wizard52 (11th September 2016)
6th September 2016 08:40 PM
6th September 2016, 09:19 PM
Moderator
Interesting read. Cheers mate
Check out my Toy -->
Rogue Dung Beetle
6th September 2016, 09:45 PM
Breadmaker Shaker
I own a stock standard td42t. I bought a catch can some years ago but it's still in the box. I have never been tempted to soup her up even though i occasionally tow a 2.5t boat. It doesnt fly. It doesnt burn rubber. It doesn't turn heads. It doesn't drone. The clutch is still good. It pulls like a teenager. It may go for as long as i live.
Probably why I'll never win the Dakar in it. Dammit!
The Following 3 Users Say Thank You to Plasnart For This Useful Post:
BigRAWesty (6th September 2016), MudRunnerTD (6th September 2016), Sir Roofy (7th September 2016)
6th September 2016, 10:45 PM
Breadmaker Shaker
Whoa! All seemed well with this article until i got to the end and my BS meter went completely off tap. What can anybody tell me about this "calibrated, pressurised spray of crushed walnut shells" so espoused? Ive never heard of it. Does Nissan offer this service?
There are approved procedures for removing this buildup, most of which use a calibrated, pressurised spray of crushed walnut shells - I kid you not - to abrade off the carbon deposits at periodic intervals.*
Because of this carbon buildup problem there are many after-market suppliers providing blank-off plates for EGR systems. It's a sufficiently sophisticated supply chain to have model-specicifc plates on offer.
Claims made for engines with blanked-off EGR valves include smoother running, improved power and reduced fuel consumption. However, our research indicates that the only measureable benefits are reduced carbon buildup in the inlet manifold and no need to clean the EGR valve periodically.*
Before you blank off your EGR or re-map its operation, bear in mind that it's illegal to do so.
6th September 2016, 11:26 PM
Some media blasting businesses use walnut shell fragments to blast so as not to damage the base metal (usually aluminum) of the part to be cleaned/blasted. Dont know about the calibrated bit though...
The Following User Says Thank You to AGman For This Useful Post:
MudRunnerTD (7th September 2016)
6th September 2016, 11:33 PM
Breadmaker Shaker
AGman
Agree. But does anyone believe Mr Nissan outsources this procedure for interval servicing of ZD30's? C'mon they're at the limit actually changing filters.
The Following User Says Thank You to Plasnart For This Useful Post:
4wheeler (8th April 2017)
7th September 2016, 07:44 AM
Enjoying the trips
Plasnart
Result of a quick google, there are plenty more;
http://walnutshellpowder.blogspot.co...gines-and.html
Just because you haven't heard of it doesn't mean it doesn't exist.
I know Allan personally, and also know he doesn't write BS in his articles. He makes a living doing this and his credibility is his major asset.
Macca
The Following User Says Thank You to macca For This Useful Post:
7th September 2016, 08:13 AM
Breadmaker Shaker
macca
Happy to back away from last nights comment.
macca (7th September 2016)
7th September 2016, 08:43 AM
Enjoying the trips
Plasnart
Cheers Plasnart
Allan had mentioned the walnuts in another article, how the boffins find this stuff works for unusual applications amazes me.
The article Cuppa linked is fairly savage on a few mods we all have done or know of someone who has, some of it a bit risky to our expensive engines / legalities / insurance.
Nissan covering an engine control sensor with oil mist has to be one of the biggest stuff ups, no wonder some keep saying clean your MAF sensor when things aren't right under the bonnet.
I'll stick with my old school 4.2 slug thankyou. hahaha
Macca
The Following 3 Users Say Thank You to macca For This Useful Post:
mudnut (7th September 2016), mudski (7th September 2016), Plasnart (7th September 2016)
7th September 2016, 09:47 AM
One can of worms opened....
So air filter socks are bad, when they clog up. So is any air filter. Chips are bad, catch cans are pretty much pointless and EGR plates dont always do as we thought. Hmmm.
