Page 5 of 5 FirstFirst ... 345
Results 41 to 47 of 47
Thread: To much boost
  1. #41
    43 Post(s)
    Quote Originally Posted by Rex13 View Post
    Havent had chance to do anything yet, but i did do a test
    100kph
    3200 rpm
    6 psi boost
    420 egt
    3rd gear (auto)
    Does this sound right?
    Na..
    Should be closer to your max boost..
    You need your max boost working properly first.. then work on your needle..
    So your needle valve is definitely closed? FYI clockwise (looking from top) to close the valve.
    In my Di Auto Im running about 14psi at 100kph @2000 rpm approx.
    Im going to re do it now as Ill be driving with the OD off in the future
  4. #43
    100kph
    3200 rpm
    6 psi boost
    420 egt
    3rd gear (auto)
    All that shows is that you have low boost, As Kallen says you should be nearer to max boost, imo
    Follow what Mudski is saying and see how you go, EG close needle and set Max boost, Normally
    10-12psi @ 100 KPH and 2000 rpm
  5. #44
    Yes
    I cant see any visable signs of it leaking
    If your IC is oily its leaking,
    OOI do yo drive a manual or auto????
  6. #45
    583 Post(s)
    If your IC is oily its leaking, OOI do yo drive a manual or auto????
    Auto as above td
  7. The Following User Says Thank You to AB For This Useful Post:
    threedogs (29th August 2016)
  8. #46
    Oct 2015
    Sydney
    Ic was leaking.
    New one installed.
    Still trying to sort out needle and dawes valve settings.
  9. #47
    A new IC will make a heap of difference,
    when its leaking you're only chasing your tail
    with no end in sight lol
