You should check what gets around down here! Some works of art about for sure!
>>>tappin from tassie
Hello from Under Down Under!
katwoman (4th August 2016), NissanGQ4.2 (31st July 2016)
Fitted the 3" exhaust today after work, unfortunately it was done in the driveway with a coupla work lights due to the troll being too tall for the shed out the back!
All good though, nice lil purrr
'09 3L CRD Gu Wagon - 3" Mandrel Bent Exhaust, 2" OME, Nitto Trail Grapplers, ARB Bull Bar, Warn Winch, Side steps, Safari Snorkel, ARB Alloy Rack, ARB on Board Compressor, Dual Batteries, Kaymar Rear Dual Bar, EBC, Reversing Camera, Outback Drawers, Fridge Slide, ARB Cargo Barrier & Divider, Rear Door Diner, Long Ranger Tanks, GME 3350s/6.6DBI, 240 Lightforce XGT's, 42' Roof Mounted Illuminator Light Bar.
threedogs (4th August 2016)
After seeing the tablet setup @Winnie had a Licola I grabbed myself a tablet & ram mount setup. Chucked in a 64gb SD card, downloaded the Hema maps & got a Telstra 4g data share sim card that links to my phone data.
Awesome setup! Can't wait to test it out properly. Also, it doesn't bloke my vision for those wondering.
'96 GQ TD42t
AB (4th August 2016), BigRAWesty (4th August 2016), jack (4th August 2016), Touses (5th August 2016), Winnie (4th August 2016), Winnies-missus (5th August 2016)
Had to go searching for this thread. No one must be doing anything.
Anyway I drove over my warn winch control several months back now. Plus my winch has been intermittent at best so I picked up this remote cheap on ebay.
Problem was its for a warn powerplant winch/compressor combo so the pin out was all wrong and it apparently has a thermal cutout. Well after scouring the web found a wiring diagram and eventually managed to suss out the correct pinout. Cut the old plug of my smashed controller and connected it to the new one. Works a bloody treat.
While I was at it I replaced my old 4 warn solenoids (most likely the intermittent issie) with an Albright solenoid.
I also swapped out the rear springs I had in with some lighter (HD) duty springs I had in the shed, it had xtra HD for a steel tray canopy ute. Hopefully she is a bit smoother over bumps now too.
mudski (8th August 2016)
See your using your spare time efficiently.👍
Sent from my XT1068 using Tapatalk
jay see (8th August 2016)
