11th July 2016, 08:28 PM
I'm stranded - 4.8 blew a radiator apart and then hole in replacement
My pressure is way up and split the top open on my radiator so I managed to get a replacement from wreckers and it either had or developed a small hole - what would cause my system to have increased pressure - I'm sitting in a car park on a night that may have snow - I have heaps of tools etc.
Heater core? Any suggestions as I'm lowcash and need to get her going at least to limp home
02 GU3 Dual Fl Y61 4.8 Auto. 3"OME, Snorkel, roof tray, Dual Batt, CB, d8r winch, ledlightco bar, fact steel BB, Elec Tow. hid spots, rvrs & tow cams, rear door rattle fix, saas dual volt gauge, mostly fin cust dash pod, ludicrous work lights. TO DO: convert headlights - led? rear tails, full overhaul trannie & engine. rear storage. door table. O/h interior storage, Paint Matt black. Bash guards. Side rails. Roof ladder. Awning.
11th July 2016 08:28 PM
11th July 2016, 08:42 PM
thermostat jammed shut hope someone is close by to help you out
The Following User Says Thank You to Sir Roofy For This Useful Post:
SpecialDave (12th July 2016)
11th July 2016, 08:46 PM
How does one Unjam thermostat?
11th July 2016, 08:52 PM
SpecialDave
if you think that's the problem just take it out and get yourself home
keeping an eye on temps you should be ok
11th July 2016, 10:23 PM
Enjoying the trips
Pressure is due to cap not working or leak from a cylinder pressurising the system.
Take the cap off and check for air bubbling out of the radiator. If not too bad you could possible drive it.
Macca
![](image.php?s=30c7d1508dc6f8e5315c10dc642542a2&u=962&type=sigpic&dateline=1361692028)
The Following User Says Thank You to macca For This Useful Post:
11th July 2016, 10:33 PM
SpecialDave
where are you?
I'd try just removing the thermostat just to get home. Hopefully this might help.
12th July 2016, 12:09 AM
Therms removed now in motion - fingers crossed
12th July 2016, 12:16 AM
Moderator
Good luck bud, hope you don't have far to go. I assume your not in the RACV?
Check out my Toy -->
Rogue Dung Beetle
12th July 2016, 12:27 AM
Nope and couldn't afford to keep roadside (going through very ordinary divorce) so it's gotten very hot and I'm pulled over letting her cool - only another 20kms to go
12th July 2016, 01:11 AM
Moderator
Bugger mate, sorry dude, that would be shit. Have you got plenty of water? Where are you? If I was close I'd come get you mate but I'm in Geelong mate.
Rogue Dung Beetle
