Results 1 to 3 of 3
Thread: Auto Trans fluid flow
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Can anyone tell me for sure which way the circuit runs from the auto through the cooler and back? I have googled it and found how to plumb it up but nothing tells me which is the direction of flow , I ASSUME It comes out of the auto and into the radiator then out of there and into the trans-cooler, then from the cooler back to the auto? I want to match it goes the other way round i.e. cooler than radiator then Trans ?
    One way will be to take off one of the hoses off at the radiator and give the engine a kickover. I think it's on the driver's side it enters the radiator.
    Edit. That should be exits, I think..
    Sent from my XT1068 using Tapatalk
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Yeah that's which 1 I'd worked out it SHOULD be mate thanks - was trying to fit the filter in the line before we got to the stage of starting it, otherwise I could just do that . Thanks Jay see 👍🏼
