Results 1 to 7 of 7
Thread: Chip or tune ?
    May 2016
    Chip or tune ?
    Would like some feedback on to chip or tune the patrol.
    Cheers. 👍🍺
    Hi mate first up what motor ,,year,,etc are you running lol
    also what do you hope to achieve, what mods have you done so far??
    exhaust etc??
    May 2016
    Srry,�� 2010 ST. manual. Has 3 inch exhaust upgrade,snorkel. Going on a trip towing a camper trailer.
    First up I would fit a Boost and EGT gauge in a pillar pod or similar.
    That way any mods done you'll be able to see whats happening.
    Then fit a Dawes and a needle valve to control your boost. Then block the EGR.
    and fit a catch can. Go buy a SCAN-gauge as well. You may find performance is adequate
    once all this is done.
    Is your Intercooler oily??? if yes then its leaking dont worry they all do.
    Best to get a fully tigged and tested 60psi from say Diesel Smart.
    Use the link to fit your boost gauge much neater IMO
    http://www.ebay.com.au/itm/331875396...%3AMEBIDX%3AIT
  5. The Following User Says Thank You to threedogs For This Useful Post:
    Hawk2014 (1st July 2016)
    Welcome Hawk..
    The crd has some advantage over the Di engines..
    But it's very tuner dependant as what they'll do..
    But good tuners will remap and close the egr that way..
    But im with TD on gauges..
    Get atleast boost and egt's in..
    I also went oil pressure but that's the farmer in me wanting to know what's going on..
    Upgrade intercooler does help and is best done before the tune.. that way it's tuned to suit better cooling. .
    Scangauge is a good bit of kit.. allows you to clear codes etc but also see what's happening with a few read outs threw the ecu..
    It's best to fit a tillix or dawes valve and needle valve and that'll give better tunability on the dyno.
    Boost pressure can be tweaked with fuel loades...
    Again, find a good tuner who knows what they are doing with Deisels.
  7. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Hawk2014 (6th July 2016)
    May 2016
    Cheers guys. Much appreciated. 👍
  9. The Following 2 Users Say Thank You to Hawk2014 For This Useful Post:
    BigRAWesty (6th July 2016), threedogs (6th July 2016)
  10. #7
    Aug 2016
    QLD
    Agree with the previous comments on doing the mods before tuning. I would be inclined to use as chip that is then set up by a good tuner on a dyno, rather than modding the factory setup itself. Just my two cents worth of course. With gauges I would reccomend using red backlit that you can adjust rather than blue backlit, just makes night driving more comfortable.
