24th June 2016, 10:54 PM
new member brett
Hi has anyone changed the steering lock and door locks,is the steering lock hard to remove any ideas would be great thanks
24th June 2016 10:54 PM
25th June 2016, 10:47 AM
pointed chisel and spin the break of bolts useing a small hammer
I never go into the outback with out a decent supply of water,
and the general rule for how much you'll need is three litres
per day , per person, per man per degree over 25 degrees
celcius, per kilometer if walking on foot, in the winter months
dividing it by two, plus... another litre... at the end .... Russell Coight
1st July 2016, 06:12 PM
I use a Drexel and cut a slot in the bolts then simply wind out with a flat screwdriver. Door locks are easy enough.
1st July 2016, 06:13 PM
*dremel, auto correct got me
