Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Vibrating sound?
    Mar 2013
    Vibrating sound?
    I have an annoying*Vibrating sound? when I hop out of my wagon, I hear a vibrating sound, if I put weight on my rock sliders it stops, if I climb back into my car it stops, if I climb under it and put pressure or pull on nearly ever component it stops, If I pull on the spring it stops, if I put pressure on my rear bumper it stops!!!!
    Can some one guide me into what to look for PLEASE, as its doing me head in
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    Is it with the engine running? Sounds like harmonics try adjusting the idle up a tad
  4. The Following User Says Thank You to Kimbo63 For This Useful Post:
    MB (3rd June 2016)
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Um shocker bleeding off air internally??? Whats a sping? how long does it vibrate for if you don't do anything?
    Mar 2013
    Quote Originally Posted by 4bye4 View Post
    Meant to say spring.
    Depending where I park some times rarely it doesn't do it, but when It does vibrates as long as engine is running...
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    sounds like that old Blonde joke
    she goes to a Drs and says "I hurt every where..............."
    "if I touch my ear,,,,,,,,,,,,,, it hurts
    if I touch my Nose.................it hurts
    if I touch my elbow...... it hurts
    if I touch my Knee........... yep, it hurts also
    what can it be Dr.........?"
    Doctor says "you have a broken finger, thats why it hurts everywhere you touch................................"
  8. The Following 3 Users Say Thank You to Bigcol For This Useful Post:
    BigRAWesty (13th June 2016), MudRunnerTD (3rd June 2016), threedogs (4th June 2016)
  9. #6
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    now, for something more constructive
    can you tape the noise on your Phone, and post it up...........
    someone may have a better idea of what it may be........
  10. #7
    475 Post(s)
    Quote Originally Posted by Kimbo63 View Post
    Donk Balance like K63 suggests!?Maybe a dodgy body mount too, steel on steel somewhere?
  11. #8
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Body mount?
    >>>tappin from tassie
    Hello from Under Down Under!
  12. #9
    Yeah I would be checking your body mounts first, then I'd look at engine and gearbox mounts.
  13. #10
    Check the exhaust mount just after the cat. I bet you its that.
