2nd June 2016, 11:08 PM
Vibrating sound?
I have an annoying*Vibrating sound? when I hop out of my wagon, I hear a vibrating sound, if I put weight on my rock sliders it stops, if I climb back into my car it stops, if I climb under it and put pressure or pull on nearly ever component it stops, If I pull on the spring it stops, if I put pressure on my rear bumper it stops!!!!
Can some one guide me into what to look for PLEASE, as its doing me head in
2nd June 2016 11:08 PM
2nd June 2016, 11:19 PM
Is it with the engine running? Sounds like harmonics try adjusting the idle up a tad
The Following User Says Thank You to Kimbo63 For This Useful Post:
2nd June 2016, 11:22 PM
Um shocker bleeding off air internally??? Whats a sping? how long does it vibrate for if you don't do anything?
2nd June 2016, 11:26 PM
4bye4
Meant to say spring.
Depending where I park some times rarely it doesn't do it, but when It does vibrates as long as engine is running...
3rd June 2016, 12:25 AM
sounds like that old Blonde joke
she goes to a Drs and says "I hurt every where..............."
"if I touch my ear,,,,,,,,,,,,,, it hurts
if I touch my Nose.................it hurts
if I touch my elbow...... it hurts
if I touch my Knee........... yep, it hurts also
what can it be Dr.........?"
Doctor says "you have a broken finger, thats why it hurts everywhere you touch................................"
The Following 3 Users Say Thank You to Bigcol For This Useful Post:
BigRAWesty (13th June 2016), MudRunnerTD (3rd June 2016), threedogs (4th June 2016)
3rd June 2016, 12:26 AM
now, for something more constructive
can you tape the noise on your Phone, and post it up...........
someone may have a better idea of what it may be........
3rd June 2016, 12:58 AM
Kimbo63
Donk Balance like K63 suggests!?Maybe a dodgy body mount too, steel on steel somewhere?
3rd June 2016, 07:42 AM
Body mount?
>>>tappin from tassie
Hello from Under Down Under!
3rd June 2016, 07:47 AM
The 747
Yeah I would be checking your body mounts first, then I'd look at engine and gearbox mounts.
4th June 2016, 05:29 PM
Check the exhaust mount just after the cat. I bet you its that.
