i'll look at under the floor but not keen on it as my fuel tank takes up most of that and would need a box to stop stones/rocks/ the ground
How far do your draws come towards your rear seats?
Can you slip one in there??
Sent from my SM-G800Y using Tapatalk
draws? what draws i want to keep the back as open as possible cos i carry tools and anything/everything in the back during the week
BigRAWesty (23rd May 2016)
What's the reason for a battery in the 1/4 panel run out of room under the bonnet.??
Don't have any pics of it with the fridge and battery sorry, but here goes.
In dads gu (mine now hehehe) he would regularly need 6-7 seats, but once I got my licence and my gq, we would take 2 cars camping. So he only needed 5 seats. Not wanting to go a full set of drawers and lose seats 6/7, he made up a bit of plywood to house the fridge, with a spot for a battery box.
He also wanted a second battery when running the fridge, but being a 4.8, with abs, and then LPG fitted, a second battery under bonnet was less likely than than a Meetup where everyone stays sober.
So we did this.
It's hooked up to a dual battery kit under bonnet, but as you can see has the Anderson plug on the side. The second battery was plugged in when needed. The cigarette lighters work when the engine is running (I.e when battery 2 would be charging if it was plugged in) or alternatively they work directly off the second battery when plugged in. Can't be seen, but there is also a tee off to another Anderson plug mounted at the rear of the car, to connect to the camper trailer battery (battery 3).
As far as a removable 3rd battery went, it was great!
Cheers.
GO HARD OR GO HOME!!!
My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
WARNING: Towballs used in a recovery can and DO KILL people!!!
blocko05 (24th May 2016)
Hi Punderhead,
I have made up 12v Accessory boxes in the past. I like the idea of using Anderson plugs.
@Punderhead I have cover plates for the empty seat mounts.
Good idea enclosing that shelf
it keeps the battery away from heat,mud, its closer to the load and one less thing on the front axle. i was planing on making a panel for everything to plug into.
BigRAWesty (25th May 2016)
