G'day all, has anyone purchased the Titan rear draws from the 4wd Supacentre, i see that they are really cheap atm,
Are they any good,
Cheers Tonks.
Are they any good,
Cheers Tonks.
2004 GU111 4.2 TURBO WAGON, 2" OME SUSPENSION, 33" MTZ's, 3" BEAUDESERT EXHAUST, ARB ROOF RACK, ARB AWNING, BLACK WIDOW DRAW SYSTEM & CARGO BARRIER, DUAL BATTERIES, 12,000lb WINCH, GME UHF, LIGHT FORCE XGT SPOTTIES, BERRIMA DIESEL TUNE.
There a bit heavy @80kgs but a good system easy to fit why pay more
for the same thing else where
Tonks (18th May 2016)
Mudski has them they are rally good in contrast to all the other rubbish they sell. Mine are arriving in a few weeks.
BigRAWesty (18th May 2016), Tonks (18th May 2016)
I actually rang Mark to ask him that exact question . I was wondering how solid that top board / fridge slide is. And he was very happy with his with his fridge on. Very sturdy apparently.
Otherwise I was going to transfer my arb slide from my current setup on top of the draws if the slide out board wasn't up to the task.
Bacho86 (18th May 2016)
Hey Tonks
They are a great item -
Had a good look at em in the outlet on display installed in their green patrol, they feel strong as buggery and definately do the job. They are very heavily built and add about 80kg empty when installed not sure if that would be an issue for some.
cheers
2001 Patrol 4.2TD manual 2" lift; Beaudesert 3" Exhaust
I have just installed a set, and yes they are heavy. By comparison, I have black widow ones in my Triton, and these are every bit as well made, with the exception perhaps of a few sharp edges. I have to say, that at about $1000 saving, its a small complaint
With regard the fridge slide, it has a front steel brace front and rear under the base board. I probably will strengthen the slide lock, its a bit light on.
My only concern is the way the side wings fit across the jack and wheel tool "port" is. Either I will somehow modify that access or have to relocate the jack etc.
GU8 2012 Simpson anniversary model, 3" redback exhaust, 2nd primary filter (original secondary), provent 200, Scangauge, engine watchdog, remote uhf dash plug, DRL's, pillarpod with pyro and boost, Titan drawer system, tail light upgrade, more to come
I hope you checked all the bearing bolts , before the install or you may find one or two falling off .
Slide latch looks cheap is cheap but is remarkably strong , mine has survived Wonnangatta, big red and most of the major tracks around the corner country and I'm still waiting for it to break .
As for the jack , in the GQ mine is still in its original spot but I've put wiring and switches on that side so put in a strip of Bunnings garden edging to hide the hole left when you take the jack cover off , I'm dreading the first time I need the jack but tested it out and I can get at it , might relocate it if it's a bugger to get out .
shantillylais (30th July 2017)
