10th May 2016, 08:46 PM
Territory engine conversion
Hi everyone, I was wondering if anyone else has considered this engine swap.
A 2.7 V6 Tdi engine from any later model (unfortunately Ford) Territory into a GU patrol.
I know that its a smaller size than the 2.8 that you can get but I was seriously impressed with the sound, the pull and the economy of this motor ...
Here are some stats from the ford website:
Territory MkII TX RWD
Engine type 2.7L V6 Common Rail Turbo Diesel
Engine size (cc) 2720
Compression ratio 17.3 : 1
Max. power (DIN) 140kW @ 4000rpm
Max. torque (DIN) 440Nm @ 1900rpm
No. of valves 24
Bore and stroke (mm) 81.00mm x 88.00mm
Injection High pressure common rail
Engine management Electronic powertrain control module
While these figures arent mind blowing, I.m sure that a chip and exhaust would make it go even better...
And they are comparable (better) than the ZD30.
I was impressed with the sound that the bog standard one at work makes, let alone something worked up a bit...
Has anyone done this or considered it?
'05 ST-S with a nice tint and LOTS more to come...
10th May 2016 08:46 PM
10th May 2016, 08:54 PM
Dribble Master
Big difference in weight though mate..... with the GU being over 400kg heavier than a Territory.
10th May 2016, 09:02 PM
Breadmaker Shaker
I have an uncle with a diesel Territory. He pulls a 25 foot caravan all over Australia, albeit blacktop only, but sounds great to me. I've never heard of any issues with this motor and instinct tells me it would be a better alternative to a ZD30. I'm not a mechanic though so this is just gut opinion without technical input. If you could get one on the cheap, and you have mechanical ability, why not give it a crack?
10th May 2016, 09:07 PM
I'm not sure
I watched an 11 second Territory once at Calder Park. Don't know how drivable that would be in the bush though!
10th May 2016, 09:15 PM
The 747
Chappy
That would be a 4.0L turbo though for sure?
10th May 2016, 09:16 PM
I'm not sure
Winnie
Not sure to be honest. I'm not well versed with them. It was impressive to see none the less.
10th May 2016, 09:26 PM
The 747
It would have to be, there are a few patrols around now with the barra engine in them. They are a really good match for the patrol.
As for the 2.7L diesel though I have got no idea.
10th May 2016, 09:34 PM
Breadmaker Shaker
Winnie
I've got no idea about Territory engines so I don't know if the uncle has 4.0L or 2.7L. Never put my head under his bonnet but sounds nice though! It's a reasonably late model but that's all I know Biskit.
10th May 2016, 09:40 PM
why not just go the duramax conversion and be done with it
10th May 2016, 10:11 PM
Dribble Master
it's a modified version of the engine first used in the 2005 landrover discovery 3 (which I know was a slug due to the weight of the Discovery), also used in Jags, BMW X5 and a few others...... built and developed by Ford UK
MudRunnerTD (13th May 2016)
