4th May 2016, 10:22 AM
#41
ebay job mate "crimefighter brand". I really only wanted something to replace central locking with an audible alert. I wont be using most of the features of this, but for $40, cant go wrong LOL.
I just hope the wiring I have above is correct...
The Following User Says Thank You to shaun100 For This Useful Post:
4th May 2016 10:22 AM
4th May 2016, 12:49 PM
#42
If its not correct if wont work.. Looking at the door lock/unlock wires it seems you have got it right. The 12v feed wire you have it on Yellow. I would say it goes to the red. And not to use the relay. The relay is for the shock sensors etc etc so when you turn the ignition off it activate the relay to disable the shock sensor. The indicators are correct.
jay see (4th May 2016), shaun100 (4th May 2016)
5th May 2016, 12:44 PM
#43
well I have tried and isnt working.....Wired as above, but with red wire as posative instead of yellow (originally a typo).
I can see the wire on the central locking getting a positive feed when locking, but it aint locking the door.....
Any suggestions...PLEASE??
5th May 2016, 12:52 PM
#44
looking through other threads, should the original plug that was to the factory keyless entry be earthed via black wire????
5th May 2016, 03:21 PM
#45
shaun100
Worth a try I suppose.??
5th May 2016, 03:47 PM
#46
Got it sorted. There were a couple of wires on alarm central locking that needed to be earthed. Now another problem. Theres a blue wire on alarm that needs a negative signal from the door. I pulled out the door switch and they are positive?? The alarm wants to rearm 20 or so seconds after I unlock and open the door, and Im guessing its because its not getting the neg signal from door light. Any suggestions guys? Thanks
6th May 2016, 10:30 AM
#47
Hmm sorry. Im out on this part. Hopefully one of the guru's will pop their head in. @Yendor @the evil twin . That might grab their attention.
6th May 2016, 06:01 PM
#48
shaun100
The interior door light switches are negative switched. Try opening and closing one of the other doors when checking the drivers door switch.
The Following 2 Users Say Thank You to Yendor For This Useful Post:
mudski (6th May 2016), shaun100 (6th May 2016)
6th May 2016, 10:28 PM
#49
Thanks Rodney...
What rims you have too mate? Sorta look like the Dick Cepek DC2's. Been contemplating splashing out on some.
8th May 2016, 12:31 PM
#50
mudski
Thanks Rodney...
Wasp
http://www.alliedwheels.com.au/produ...lack-machined/
