5th May 2016, 05:07 PM
#31
Enjoying the trips
threedogs
They can be a bugger to lift in at the best of times,LOL
Just a reminder to wipe the posts with a green scourer.
Did it have much crud under the battery ???
Did you get the same brand as a replacement.??
Do you grease the terminals? Never know whether to cover the post before fitting the clamp and then cover the lot or not do it at all.
Macca
5th May 2016 05:07 PM
5th May 2016, 05:10 PM
#32
macca
squirt of crc does the same
The Following User Says Thank You to Sir Roofy For This Useful Post:
BigRAWesty (5th May 2016)
5th May 2016, 06:15 PM
#33
You'll find new batteries have a protective coating that needs to be removed,
I usually squirt a small bit of terminal spray when finished, weather proofs the lot.
Even Lanotec will work,,,,, great product IMO LOL
5th May 2016, 10:06 PM
#34
Enjoying the trips
How did you go @roofy ? Did @Winnie install it and test the engine run volts?
Macca
5th May 2016, 10:14 PM
#35
macca
Very unusual for a battery to be a dud, but I don't really know too much about them.
Concerned it's in the car as suggested, but more than happy to be proven wrong.
You don't need this!
I've just had a 120 ah dual purpose one shat itself only 4 months old..
It just started self draining and in the end nothing would bring it up in charge..
Got it replaced and so far it seems good..
6th May 2016, 07:26 AM
#36
Sounds like good news roofy, Hopefully it was a dud and no more probs now. . .
6th May 2016, 08:03 AM
#37
Rossco
Hope so mate just need to run a good multi metre over it
to be sure
6th May 2016, 10:24 AM
#38
The Following 2 Users Say Thank You to Sir Roofy For This Useful Post:
macca (6th May 2016), Rossco (6th May 2016)
6th May 2016, 10:27 AM
#39
How many CCA 750 or higher???
6th May 2016, 10:38 AM
#40
threedogs
760 mate-----------
