Spent most of the morning under the troll looking for a lost earth. Found a broken wire in the rear bumper loom. Now have the rear lights working independently of each other again. It was more interesting before though, you just had to know the code. RH brake flashing means turning right. RH brake and indicator hard on means braking. RH indicator and brake half on means park lights are on and so it goes, Anyway all fixed now so I can go away at Easter and brake it again. (pun intended).
too much stuff
one of those plastic grab kits has arrived with an assortment of different
size split pins/cotter pins. Just one of those workshop things thats handy to have
if you you ever need a split pin
A couple of test lights have arrived, the brass looking one with the covered tip will stay in the Patrol
The other will go in with my shed tools, for ever losing them with 2 boys
Had a special at the local 4x4 shop. still got some wear on the other MTZ that's on the Ute now, so these will come in handy later.
Macca
Rossco (25th March 2016)
Very nice what size Macca ??
