Page 248 of 568 FirstFirst ... 148198238246247248249250258298348 ... LastLast
Results 2,471 to 2,480 of 5675
  1. #2471
    Thomastown, Melbourne
    6 Post(s)
    Picked up some twin piston ti calipers from Patrolapart. Just need to get some braided brake lines and hopefully have better brakes! !
    I have all that and still have shit brakes... i dont think my rears are working properly as they have still hardly worn.
    Quote Originally Posted by Bloodyaussie View Post
    Check the Brake Proportioning Valve - known problem on the Trols and a lot of other vehicles as well
  4. #2473
    194 Post(s)
    Yeah i was thinking about that earlier today actually! ! . . . Well in "theory" they should be better . . .
  5. #2474
    6 Post(s)
    What is the main issue with them as i have played around a bit with it but seems to be no difference with anything i do.
  6. #2475
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Spent most of the morning under the troll looking for a lost earth. Found a broken wire in the rear bumper loom. Now have the rear lights working independently of each other again. It was more interesting before though, you just had to know the code. RH brake flashing means turning right. RH brake and indicator hard on means braking. RH indicator and brake half on means park lights are on and so it goes, Anyway all fixed now so I can go away at Easter and brake it again. (pun intended).
  7. The Following 2 Users Say Thank You to 4bye4 For This Useful Post:
    macca (20th March 2016), Stropp (20th March 2016)
  8. #2476
    Aug 2014
    Perth
    10 Post(s)
    too much stuff
  9. #2477
    one of those plastic grab kits has arrived with an assortment of different
    size split pins/cotter pins. Just one of those workshop things thats handy to have
    if you you ever need a split pin
  10. #2478
    A couple of test lights have arrived, the brass looking one with the covered tip will stay in the Patrol
    The other will go in with my shed tools, for ever losing them with 2 boys
  11. #2479
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Had a special at the local 4x4 shop. still got some wear on the other MTZ that's on the Ute now, so these will come in handy later.
    Macca
  12. The Following User Says Thank You to macca For This Useful Post:
    Rossco (25th March 2016)
  13. #2480
    Very nice what size Macca ??
