For those that run Ozi Android there is a new update available. Fixes lots of little problems.
Thanks mate. I'll give it a go as I had a lot of issues with my Hema maps pack. Been using the Explorer so havent fired up the Ozi for a while.
For those that run Ozi Android there is a new update available, 1.28. From the Ozi site
Version
1.28
Android 6 (Marshmallow) caused a crash when loading ECW map images - has been fixed
Android 6 (Marshmallow) changed the name of the external SD card and this means the OziExplorer Map File path is no longer valid. OziExplorer now notifies the user that the path is no longer valid and to set it to the correct path in configuration.
Added the ability to turn off waypoint dragging in Waypoint Configuration - the default is OFF. I did this to remove the accidental activating of waypoint dragging. Improvements should be made to waypoint dragging in future versions.
Much difference between Ozi for Android and Androzic? I've been using Androzic for a donkeys age and generally works pretty well.
