Results 1 to 10 of 15
Thread: Boost Pressure
    Feb 2016
    Boost Pressure
    hi guys, where is the best place to pick up boost pressure from on a 2001 3.0l di?
    Cooper
    http://www.ebay.com.au/itm/331773948...%3AMEBIDX%3AIT
    Found this to be the neatest way,
    Feb 2016
    Cheers, do i need anything else with it other than a boost gauge and will any boost gauge kit from ebay fit?
    Yep you should be right I used 4mm efi fuel line and then clamped that to the teflon tubing or cable tie
    or you could use a 1/8th fitting that excepts an olive type join
    465 Post(s)
    Weld a bung in the front ic pipe. If you have access to a welder....
    Feb 2016
    i think im going to weld a bung in to save money, but what pipe the i weld it into? the outlet or inlet side?
    There is a spot under the IC that you can drill and tap as well.
    thats where mine was originally.
    OOI do you have a tigged intercooler, is it the original
    and oily
    Feb 2016
    it is the original intercooler
  10. #9
    465 Post(s)
    I had the bung in the front pipe where it says outlet pipe. The pipe after that short rubber section.
    BigRAWesty (7th March 2016)
  12. #10
    Feb 2016
    cheers guys
