Yep you should be right I used 4mm efi fuel line and then clamped that to the teflon tubing or cable tie
or you could use a 1/8th fitting that excepts an olive type join
There is a spot under the IC that you can drill and tap as well.
thats where mine was originally.
OOI do you have a tigged intercooler, is it the original
and oily
