How's the build coming along OLY great thread mate
Hey Oly, I have a 91 Nissan GQ - she's in great shape but had a hard life with the dirt roads over here in Tanzania. I would like to take the body off the chassis for two reasons - the first, to brace the rear suspension mounts as you have done and the second, for a complete respray before fitting some sound insulation and new carpets etc and third, to replace all of the bushes and engine mounts. How hard is it to remove the body from the chassis? What time is involved? Have you got a diagram of all of the bolts holding the body to the chassis? Sorry for the hundred questions, relatively new to the forum and looks like you are doing more or less what I'd like to do...
BigRAWesty (9th February 2016)
It is a big job that's for sure. Unsure on a time frame though..
There are 10 bolts in a wagon.
4 do either side of the cabin and 2 next to the radiator.
There is a main loom plug under the passenger seat (we have right hand drive cars so unsure if it's the same for left hand drive)
But then you also have to strip out things like air conditioner hoses to body, heater hoses, brake and clutch lines, fuel lines, battery cables and whatever else there is in the engine bay..
hey fella's sorry about the late reply, have been flat out lately, and the mrs car sh!t itself so that's taken a bit of my spare time too (who'd buy a cruiser, honestly)
I have done a little bit i'll have to load up some photo's cab is nearly ready for paint..
Shummezz it's not a technically difficult endeavour to lift the cab and if you plan on putting down sound deadener then all the carpet and inside goodies will already be out. Westy is fairly onto it with having to pay attention to making sure everything underbonnet is disconnected such as air con and things and all of the wiring does unplug so not too bad there. the crappy bit to look out for is the two rear cab mount bolts that come up from the bottom have a really weak cage holding the nut so spray with WD40 and some freeze and release every day for at least a week before attempting to undo them. sometimes they break anyway and you have to cut a larger hole as I did anyway. a hoist also helps because the way I lifted the cab was sh!t too..
Run Your Fingers Over My Patrol, I'll Run My Patrol Over Your Fingers!!
so as i mentioned progress has slowed down alot. but hasn't completely stopped
these photo's show where the front clip had separated from the cab below the windscreen
welded the back up and welded the last few cracks in the front inner guards
then i went and found myself one of these brace kits, painted it up as it would be a bit hard to get to after its welded
and set about zapping them in
i had to run through the passenger side brace with a 3 and a half inch hole saw for the snorkel hole before i could finish welding it in and i'm going to try slip a piece of pipe in to fill the hole so i'll head to the steel shop tomorrow to try to find some.
after bracing the front i started on the back...
pulled these little trim bits off
bit of marking out 10mm down from the crease, a bit of duct tape gives me a nice straight edge
then i very lovingly cut the f*#kers off with a grinder. It was getting a bit dark so i didn't get any more photo's but i'll grab some tomorrow and hopefully weld the plates on the bottom
Looking good mate. Where did you get those brace kits from, i like those. Have a suspicion mine is making some clunks from that area.
Rossco (5th March 2016)
a few quick snaps of the rear quarters cut off and the plates being tacked on
a few little dents sanded. then i beat them out as best i could and filled them up
after sanding back the whole cab it's now in primer, starting to get to the pointy end of the stick
and a couple that i forgot to put up before of the pipe where the snorkel hole is
BigRAWesty (10th March 2016), mnoga (5th September 2016), Robo (11th March 2016), Rossco (10th March 2016), Wine_maker (11th March 2016)
