5th February 2016, 08:24 PM
NissanGQ4.2
Bit hard 2 see in the pic but the bolt holes on the diff bracket are elongated, like Kallen has suggested
Attachment 64626
Just loosened the nuts and checked the holes. . . . and what do you know, I have elongated holes, about 1mm on each side! My next question now is, how do I fix them? I was thinking of getting some heavy duty washers the same size as the bolt and welding them to the hangers, but then I'd need longer bolts to account for the washers.
Andrew
The Following User Says Thank You to Wetty For This Useful Post:
BigRAWesty (5th February 2016)
5th February 2016 08:24 PM
5th February 2016, 11:35 PM
Wetty
Andrew
Grab some weld on washers from threedogs.
You'll need 8 and 4 new m16 grade 8.8 bolts 110mm long preferably in a metric fine thread..
Remove bolt, insert a washer either side, tighten and the weld them on..
Wetty (6th February 2016)
6th February 2016, 04:44 PM
have you checked the CVs
The Following User Says Thank You to Dorizzi88 For This Useful Post:
Wetty (7th February 2016)
6th February 2016, 05:03 PM
Like i said.... nearly always radius arms.
The Following 2 Users Say Thank You to Bloodyaussie For This Useful Post:
BigRAWesty (6th February 2016), Wetty (7th February 2016)
6th February 2016, 06:25 PM
Dribble Master
Bloodyaussie
Or body mounts.... but not n this case lol
19th February 2016, 07:55 PM
Well, I welded some steel plates to the front holes for the radius arms today, but my clunk is still there, albeit not as loud and not as noticeable through the floor pan . . . . . looks like I will be checking the rear holes now, and if that doesn't work I'll just drive around with the stereo up full noise so I can't hear or feel it
Clunk (19th February 2016)
20th February 2016, 07:52 AM
#17
haha thats been my solution for the car i sold... didn't want to fix it
20th February 2016, 08:36 AM
#18
also maybe check the shocks rubber bushes if you cant find anything else
Wetty (20th February 2016)
20th February 2016, 09:03 AM
#19
i got rid of alot of noises by replacing spring pads. mine were worn through
20th February 2016, 09:52 AM
#20
garett
Did that too, drivers side was gone and squeaked every time I got in the thing. . . . the knock is definitely on the passengers side so I'll check it out when my body recovers from lying on the concrete with spanner in hand!
