Results 21 to 30 of 34
Thread: 5th gear low range manual, what speed should I get at 3000rpm? ?
  1. #21
    Mudski we are not talking beach sand here which is compacted by water. Super soft power sucking sand!
    mudski (12th January 2016)
  3. #22
    North brissy
    Maybe the beaches are different down SA way to up at QLD. When I was on Moreton I don't think I even used low range. I suppose for the dunes it would be a lot different though! Just high 1st or 2nd mainly for the hills and boggy sand and just plenty of the right foot... Out on the open beach runs just cruised in high 4th, in 2wd sometimes made for awesome rooster tails. Lol.
    Power makes a lot of difference in the sand. Ever seen what a turbo 4.8 does on sand?
  4. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    BigRAWesty (12th January 2016), mudski (12th January 2016)
  5. #23
    Feb 2011
    Shed
    45 Post(s)
    The sand down Southend, Beachport, etc is FLUFFY and will catch the unwary very quickly
  6. The Following User Says Thank You to growler2058 For This Useful Post:
  7. #24
    Expert tuckertrucker's Avatar
    Aug 2015
    Far North, New Zealand
    I've written a calculator for speeds in excel. The FS5R50A trans bolted to a TX12a with the stock 2.020:1 low range reduction on 31" tires will do 64 km/h @ 3000 rpm.
    You're also very right about driving at speed in low - its often a necessity. I'm often on long sandy beaches and stopping to go into high is just not possible once Im moving. And on the beach I rarely go over 50km/h any way so low range is well suited. Also due to the high reduction, you've not got as much load on the motor which I find keeps the temps down, and keeps the amount of power still available up
    1992 Nissan Safari Granroad LWB TD42 after market turbo RE4R03A (for now) 3" straight pipe
  8. The Following 2 Users Say Thank You to tuckertrucker For This Useful Post:
    BigRAWesty (12th January 2016), MudRunnerTD (12th January 2016)
  9. #25
    Quote Originally Posted by tuckertrucker View Post
    Well I'd say that Calc is pretty well spot on its splitting hairs ey..
    Out of curiosity what would a set of marks 24% reduction gears take it to??
  10. The Following User Says Thank You to BigRAWesty For This Useful Post:
    tuckertrucker (13th January 2016)
  11. #26
    North brissy
    48.64km/h.
  12. The Following User Says Thank You to nissannewby For This Useful Post:
  13. #27
    48.64km/h.
    So it literally is straight 24% reduction??
    Feb 2011
    Shed
    45 Post(s)
  15. #29
    Them there are just guide lines.. lol
    Aug 2015
    someone correct me if Im wrong, but 2.020:1 is roughly 50% reduction correct?
