Started installing the uhf..
Coax and antenna installed..
Now just to find out why I have no power to the plug that's there..
BigRAWesty (4th January 2016)
That would mean you would have to test it on a local track or two. I haven't seen a diesel on the dyno though, it would be interesting to see how much your CRD produces
and the shape of its torque curve.
BigRAWesty (5th January 2016)
Bled the front brakes, then the proportioning valve, then tried on the rear left, bleed screw seized. Then tried the rear right, stuff all fluid coming out under pressure. Hmm. I remove the calipers to find that one is seized and the other almost. Now to find a new piston for one of them tomorrow. Otherwise the old pitted one goes back in.
BigRAWesty (5th January 2016), mudnut (5th January 2016)
