Page 585 of 1056 FirstFirst ... 85485535575583584585586587595635685 ... LastLast
Results 5,841 to 5,850 of 10559
  1. #5841
    Starting to turn into a real 4x4, should be fully installed early next year.
    Thought this was the best position for the switch, very easy to reach, next
    switch hole will be the Roof light bar and the third will be compressor.
    Then on the centre console Ill fit a winch isolation switch and a
    winch in/ winch out switch. well thats the plan he he
  2. The Following 3 Users Say Thank You to threedogs For This Useful Post:
    BigRAWesty (22nd December 2015), Clunk (22nd December 2015), mudnut (22nd December 2015)
    How's the serenity boots's Avatar
    Sep 2011
    Airbag recall dealt with and fixed by local dealership today.
  5. The Following 6 Users Say Thank You to boots For This Useful Post:
    BigRAWesty (23rd December 2015), Hodge (22nd December 2015), katwoman (23rd December 2015), Maxhead (22nd December 2015), Stropp (22nd December 2015), threedogs (22nd December 2015)
  6. #5843
    So there on..
    Bit of stuffing around with the clips but I'm a happy man..
    Once it cools a little in the new year I'll paint it all black.
    The awning sits nice and low which is what I was after aswell..
  7. The Following 4 Users Say Thank You to BigRAWesty For This Useful Post:
    Clunk (26th December 2015), mudnut (24th December 2015), Stropp (24th December 2015), threedogs (28th December 2015)
  8. #5844
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Did the 5k oil and filter swap - made a damn good mess taking out the filter too! Turns out the factory drip tray under the filter was either clogged or just not working cause the oil didn't come out the tube into the bucket just flowed straight over the top all into the driveway lol
    Also put a new set of Bendix brake pads in the front, bleed the system and put some fresh brake fluid in! Job done!
  9. The Following 2 Users Say Thank You to Bacho86 For This Useful Post:
    BigRAWesty (26th December 2015), Hodge (26th December 2015)
  10. #5845
    Patrol Guru Rocket55's Avatar
    Sydney
    Best do an update in here, over the last week I've put in a set of genuine gearbox mounts, genuine drivers side engine mount, Superior Engineering passengers side engine mount, 3 core Rapid Cool brass and copper radiator, upgraded UFI fan and fan hub, new power steerng, alternator and air con belts, thermostat, VDO temp gauge, 2 x oil filters, fuel filter, 10.5L Dello 400 oil.
    Cheers Rod
    My Build 2005 TD42TI
  11. The Following 2 Users Say Thank You to Rocket55 For This Useful Post:
    Clunk (26th December 2015), Hodge (26th December 2015)
  12. #5846
    Feb 2011
    Shed
    45 Post(s)
    Fitted the egr blanking plate TD sent me AGES ago! Cheers CockO
  13. The Following 2 Users Say Thank You to growler2058 For This Useful Post:
    BigRAWesty (4th January 2016), threedogs (28th December 2015)
  14. #5847
    Patrol God Stropp's Avatar
    32 Post(s)
    Took a quick 1100 k trip for xmas in Denmark on the south coast then dropped in to annoy avo'dcardo 🙄Had a good night as usual.
  15. The Following 2 Users Say Thank You to Stropp For This Useful Post:
    Clunk (28th December 2015), Skitzyrex (28th December 2015)
  16. #5848
    Jul 2012
    N/a
    Gave her a wash
    Put is a new switch panel
    And cleaned all the earth straps up
  17. #5849
    Sydney
    Installed a new box of tunes
    Cheers Rod
  18. The Following 5 Users Say Thank You to Rocket55 For This Useful Post:
    BigRAWesty (4th January 2016), Dinger (29th December 2015), growler2058 (29th December 2015), rusty_nail (29th December 2015), threedogs (29th December 2015)
  19. #5850
    Feb 2011
    Shed
    45 Post(s)
    Not today but yesty i washed it after doing the egr plate.
    Today i drove it to work YAY
