Results 1 to 10 of 12
Thread: What size mig wire should I get?
    465 Post(s)
    I have a Cigweld Mig 135 here and I need to get some wire. I have a gas bottle here to use and was using 0.8mm gasless wire, before getting the gas.... MY local shop has 0.6mm or 0.9mm gas wire. It will be for general purpose welding, your usual RHS and angle iron type stuff. If i get the 0.6mm this might be better for real light stuff like panel etc, but maybe not so good for general steel welding. Not sure on this....
    Cheers.
    Mark.
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    I use 0.8 for everything. It's fine for 1.6mm exhaust pipe or 10mm thick plate.
    If I had something really thick to do I'd just swap the roll to 0.9 but I can't remember the last time I had to do that.
    John
  4. The Following User Says Thank You to jff45 For This Useful Post:
    mudski (27th December 2015)
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    I would be more inclined to go 0.9 over 0.6. Maybe try a different place to get 0.8. It's pretty common.
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  6. The Following User Says Thank You to lhurley For This Useful Post:
  7. #4
    Morayfield, QLD
    If your gun and liner are suitable for 0.9, using 0.6 in it will be annoying. It's like the proverbial .... in a shirt sleeve.
    I bought a Parweld gun for max 0.8 and it's really good. I have to switch guns if I want to use 0.9 now.
    John
  8. #5
    Oct 2011
    I have the same welder, will run 0.9, even 1.0. I however only run 0.8 in mine as it was most suited to my application.
  9. #6
    Morayfield, QLD
    The welder is a Unimig 240 and the original Unimig gun will take 1.0mm which makes the 0.8 sloppy in the liner.
    The guns have Euro plugs so easy to switch over.
    John
  10. #7
    465 Post(s)
    I can switch tips in the gun to suit the wire size if this is the same thing...
    if 0.8 is better i will see if i can get it from another shop. But if i cant?
  11. #8
    Morayfield, QLD
    Not the same thing. The tip must match the wire anyway.
    If your liner is too big for the wire size, you can pull the wire in & out 10 - 15mm and this can give you erratic wire feed.
    I found Cigweld 0.8mm wire at Masters.
    You can also use your 0.8 gasless wire with gas as well. I'm told it gives pretty good welds but I've never tried it.
    John
  12. The Following User Says Thank You to jff45 For This Useful Post:
    mudski (28th December 2015)
  13. #9
    I use .9 and it does the lot just adust the feed and amps for thinner material
  14. #10
    Oct 2011
    Most tool shops sell it. Google some local welding supply shops too.
