16th December 2015, 02:31 PM
#31
Travelling Podologist
qwertytank
Looks reasonable to me. A known quantity in the compressor, a decent warranty as well as 2” insulation which is as good or better than a lot of the common models. I wouldn’t call it cheap, but it does seem reasonably priced in comparison to what else you can buy. I like the internal lids as well as the the main lid.
qwertytank (16th December 2015)
16th December 2015 02:31 PM
16th December 2015, 06:12 PM
#32
Well, with minimal research, I went for a Waeco 40.
Good bad or indifferent, it is done now, let the chips fall where they may.
16th December 2015, 06:40 PM
#33
RedRoadRunner
Just make sure you have good connections and steady 12 v supply .
You should have no problems IMO
16th December 2015, 06:48 PM
#34
I've got a second battery on the way...
Might do a little 12v wiring on the weekend...
16th December 2015, 06:55 PM
#35
Give any cig sockets the flick they do fail and not the best going.
use either twistlock Engel/Baintech style, even 50 amp anderson will
do the trick. Make sure your wire is adequate to carry the current to the rear of the Patrol,
Even a merit socket and plug would be OK
When you fit your Dual battery tray please use Mudguard washers [penny washers]
and nyloc nuts, Ive seen too many GQs with broken inner guards from poor fitting
practices.
#36
lucus30
Ah typo for me... ha ha meant 220V
But yes that 2nd one does look better. So have you installed this into yours?
Interesting idea... Got a mate that had a busted engel I should try and fix
Ive used this temp controller on my engel setup too mate. Works a treat.
The Following User Says Thank You to sooty_10 For This Useful Post:
threedogs (16th December 2015)
19th December 2015, 06:01 AM
#37
Well, after a little retail adventure, getting all the tools ready, and spreading shit all over the kitchen table to do surgery....I realised that the Waeco plug just has a little sleeve on it you can take off and it fits in a merit socket.
19th December 2015, 09:42 AM
#38
Doh,,,, welcome to the club, now to mount the
Merit somewhere where it cant get knocked .
20th December 2015, 11:30 AM
#39
Right above the fridge, so I can snap the plug when I open the door incautiously.
20th December 2015, 01:04 PM
#40
There are a few options to mount it, I have used an Engel transit base ,but that wont work for you.
There are two styles of fridge slides one slides and the other $$$$ slides and drops down.
Make sure you restrain the fridge from moving around maybe use some rachett straps.
Where are you putting your fridge???
