So you can see supply and return on the sender unit,
And filler, quick fill breather and expansion breather.
Then 2 more left of pic, which are at the rear of the tank..
And yes, I'm missing a mount..
Yep um guessing that mount is that pita one to get off. If only I knew a decent welder... ;-)
Seems weird to have a pickup on the sender and tank??
Also Westy being yours is probably the same as mine and out of a carby to be used as an aux tank on a dual neck filler you will need a reducer for the aux filler hose.
The aux tank will be 48mm, I can't remember what the neck will be but it will be smaller in diameter so you'll need a reducer.
Na not running a dual filler neck, I'll be running an overflow setup.
Found it!!!! 4th page of a 'LRA sub tank maunal'....
Sorry for resurrecting old post, but what do you mean by overflow setup, I'm at that point now. Thanks
