29th October 2015, 06:22 AM
Worn out.
Hi. I have been out with a mate of mine for a bit of a drive( out Burra way) and my Mav couldn't go half the places he could( he has 2005 prado) can anyone explane. Someone said my diff was worn out. Can a diff wear out ?
29th October 2015 06:22 AM
29th October 2015, 06:50 AM
At a guess I'd say he traction control
29th October 2015, 07:02 AM
Did you put yours in 4WD and lock your hubs.??
What tyres do you have fitted
29th October 2015, 08:35 AM
Yeah what kind of setup do you have mate? What was stopping you from going places? Tyre spin?
If both vehicles are setup the same then the patrol will be an easy match and in a lot of cases it should out drive the prado off road
tappin from tassie
Hello from Under Down Under!
The Following User Says Thank You to taslucas For This Useful Post:
BigRAWesty (29th October 2015)
29th October 2015, 10:31 AM
I had lots of wheel spin but only on one side. Selector in centre of front wheels in lock. Standard tyres fitted. I think 31r15
29th October 2015, 12:02 PM
Did you select low range with the little stick inside the car and did you drop your tyre pressures.
After locking your hubs via the centre of your wheels you have only locked the hubs in.
If not you have done very well keeping up with him in 2WD, great effort
29th October 2015, 12:14 PM
Dancing Chicken
As TD said above, are you sure 4wd was properly engaged with gearstick?
The front diff will be an open diff so it will spin the wheel with least resistance. With standard all terrain tyres in slippery circumstances it will spin both easily.
The rear diff is an lsd so if working correctly it should spin both rears when in slippery conditions. Even though patrol rear lsd diff's are the best around, it is possible for them to loosen up with age and wear.
Perhaps check the fluid levels and condition in the diff's to see if they look healthy.
Also, maybe it's time to go for some grippier tyres.
How long have you had the maverick and do you have much experience off road?
tappin from tassie
threedogs (29th October 2015)
29th October 2015, 12:32 PM
With any "normal 4WD when you lock the hubs and select low 4WD you in affect only have two wheels driving you forward .
the rear right and the front left but as we have patrol we have a LSD in the rear and a bloody good one at that.
Sometimes when 4x4ing if one wheel is in the air and spinning [front] its a trick to tap the brake to get drive to the none spinning wheel.
29th October 2015, 03:16 PM
LSD ???? Sorry fellas. I'm lost.
29th October 2015, 03:17 PM
Dribble Master
Dancing Chicken
Limited Slip Differential
taslucas (29th October 2015)
