22nd September 2015, 01:05 PM
#21
22nd September 2015 01:05 PM
22nd September 2015, 03:38 PM
#22
Not to scale but basically what I have done,,, short run from the mppt to the battery
Only thing I'll change is the way I hook up the panel using those MC4 connectors
instead of a 50 amp anderson plug, Bummer as I need to change all my panels
80 watt, 20 watt and a 10 watt,plus my new one 120 watt
@ Bob did you have yours screwed onto a board or something
maybe screw it in a low tupper ware dish with some vent holes
22nd September 2015, 03:55 PM
#23
threedogs
Installed in a sealed Box which is opened when in use
A bit junky at present but this is how close to the Battery
The Following User Says Thank You to Bob For This Useful Post:
threedogs (22nd September 2015)
22nd September 2015, 06:03 PM
#24
I am he, fear me
I'm not 100% sure those Redarc's are a full MPPT controller, could well be but they are certainly a good quality unit.
22nd September 2015, 06:12 PM
#25
the evil twin
I'm not 100% sure those Redarc's are a full MPPT controller but they are certainly a good quality unit.
Please explain what you mean
22nd September 2015, 06:26 PM
#26
I am he, fear me
threedogs
Very, very rare to find a good MPPT below a couple of hunjy. Good name brand will be $300 and up
As a point of interest the 25 and 40 Amp jobbies in the BCDC series are quoted as MPPT by Redarc but the SRP series wasn't AFAIK
Depends on the guts but a big MPPT Controller will take 60 to 150 Volt panel input give or take.
I 'think' they can get the costs down of the MPPT if they limit the Panel Voltage and it's interesting that Redarc quote a max panel input of 30 odd volts
30 volts is the normal limit for a PV controller ergo those 10 and 20 amp redarc stand alone jobbies may be MPPT but personally I am not 100% sure.
Best way would be to check with Redarc but either way you know you are getting a good controller
22nd September 2015, 06:41 PM
#27
the evil twin
I went with the Redarc as they can be set for Calcium Batteries (Which I have).
22nd September 2015, 06:50 PM
#28
I am he, fear me
Bob
Good choice.
I really rate Redarc and Intervolt, both Aussie and both very high quality.
If they don't have what I want I tend to use Ctek... or... Morningstar or Tracer for industrial applications
24th September 2015, 03:37 PM
#29
@ ET my MC4 connectors have arrived, do you them together or alternate them
As in on the Panel do i use f and f or f and m, I dont see how it would make
much difference.
24th September 2015, 04:10 PM
#30
I am he, fear me
threedogs
much difference.
It will make a difference if you cross connect 'em...
The convention is...
The MC4 should have a -ve if you look close goes to the -ve output lead from the panel
The Following User Says Thank You to the evil twin For This Useful Post:
threedogs (24th September 2015)
