Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Which brake pads?
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Which brake pads?
    Yeah, yeah I know its been covered before but I need to replace me pads
    I'm taking off for a couple of weeks in the van and my pads are near worn so I need to change. The original Nissan pads are crap so I need something a little better to pull me up a little quicker.
    So what is the go??? I don;t really want to change the rotors at this stage
    ________________________
    ______ 2017 D-Max _______
    ACT
    Ok, I changed my mind and I might do new rotors as well
    You can get new dimple drilled and slotted rotors plus green/black pads for about $100 a corner.
    ACT
    Any particular brand you recommend John. I've seen a few on eBay and bandix seem to be cheap but not sure they're best
    RDA I think I fitted ,not convinced fitting green HD was correct.
    Having an auto I would be on the brakes more but I dont think they get hot enough to be efficient.
    The rotors themselves apart from looking the part do their job, I might go a softer pad and change them more often.
    Ron Moon uses Kevlar pads in his patrol but they chew the rotors but they work very well indeed.
    Autopartsonline I think was the mob.
    Next step for me would be some ADR braided hoses from out Vendor sponsor
  6. The Following User Says Thank You to threedogs For This Useful Post:
    Maxhead (13th September 2015)
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    dont use the standard rda rotors ....(they have warped under heavy braking). their slotted and dimpled ones work alright so far. i went with dba survival t2 rotors for my mav. but not really tested them yet.
    bendix pads are alright but not always the best, pends on the car. not sure about their 4wd range.
  8. The Following User Says Thank You to garett For This Useful Post:
  9. #7
    Might be worth sending a PM to our braking sponsor, then you can explain
    what you use the Patrol for and what you expect out of the braking, new pads and some braided hoses may be all you need.
    Remember not everyone has the same useage from their brakes, auto/manual completely different, Ute/ wagon again different.
    heavily modded to a stocker, all different IMO
  10. The Following User Says Thank You to threedogs For This Useful Post:
  11. #8
    331 Post(s)
    I run off road Bendix pads in the guiv and they are great. Stop well.
  12. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  13. #9
    I use bendix pads too and think they're great.
  14. The Following User Says Thank You to Winnie For This Useful Post:
  15. #10
    ACT
