Results 1 to 10 of 11
Thread: Where to fit BCDC1240??
    Oct 2013
    Port Hedland
    K Gents
    Where have you mounted your smart BCDC1240?
    I have just purchased one to do away with the SBI 12v Isolator.
    Now i just need the best spot to mount it.
    What vehicle? I mounted mine under the lhs dash. I had it in the engine bay but these dont like heat so under the dash it went. GU Patrol here too. Lol.
    175 Post(s)
    WHat car mate? THis is where my one is fitted on the 3L. I made a stand off bracket off the body.
    My 4.2 L is now a different setup but in the same area. Will take a pic when I'm done.
    Oct 2013
    Port Hedland
    Nice. 2009 GU sorry should have added that
    Patrol Guru Rock Trol's Avatar
    Mar 2013
    NE Melbourne
    I have the 1220 in the engine bay and it seems to work ok. A couple of mates also have them there. It is a shorter unit though and fits near the battery.
    175 Post(s)
    Quote Originally Posted by cjb View Post
    Yeah mine was a 2009 Common rail and thats where I had it in the above photo !
    Oct 2013
    Port Hedland
    Photo of the standoff bracket for the 3L would really help.
  9. #8
    Expert Wetty's Avatar
    South Guildford WA
    I had mine under the bonnet on the driver's side above the brake booster but it was getting way too hot and I couldn't see what the thing was doing either, so I mounted it under the dash on the driver's side and used heavier gauge wires as was recommended in the destructions.
  10. #9
    Oct 2013
    Port Hedland
    Wetty do you have any pics of where you mounted it?
  11. #10
    South Guildford WA
    Hi CJ, sorry no I don't but it is screwed to the plastic panel alongside the steering column if that helps? No issues with knees or shins hitting it either (I was going to mount the UHF there but it was too big)
