taslucas (24th August 2015)
Yeah the shock tower is hard against the body now. Had to manipulate the drivers side a little but all in now.
Biggest issue for me was how I was going to get to the top nut on the shock but the hole sorts that out.
I've seen you lebo slingshot liftlid and I'm surprised the body is still attached at all let alone punched through with holes!
tappa lives!
Hello from Under Down Under!
liftlid (26th August 2015)
Hey Mudrunner just had a quick question about when you moved the primer pump back over to the drivers side (roughly page 110 I think) . Did you take the wring for the water in fuel plug with it or not worry about it? If so, how did you do that. Just about to do the same on mine and after any tips. Cheers.
Hi mate, sorry I completely missed your post. Sorry for not following you up.
I have run an after market fuel filter for 10 years with a water separator so the wiring is obsolete on mine. Would not be difficult though I would think. Knowing Nissan it probably leaves the loom on the drivers side and goes across the fire wall anyway.
Hope you got it sorted mate/ feel free to ask away.
BigRAWesty (16th October 2015)
Nah all good mate. Yeah pretty sure it is in the loom on the drivers side and just goes across the inside of the firewall and then out the other. Haven't got around to it yet as have had bigger dramas. Cheers though.
MudRunnerTD (25th November 2015)
What have we got here?
48.3 OD pipe. Hmmmmmm
And a nice bender!!!
Time to get busy!
Brush bars for the GQ and GU
Making Sliders for the GU
Tomorrow is going to be a great day!!
AB (30th January 2016), BigRAWesty (30th January 2016), jay see (31st January 2016), NissanGQ4.2 (30th January 2016), Plasnart (30th January 2016), Winnie (30th January 2016)
