Page 116 of 187 FirstFirst ... 1666106114115116117118126166 ... LastLast
Results 1,151 to 1,160 of 1862
Thread: MudRunnerTD's GQ From the Ground Up
  1. #1151
    How did the rear
    spring tower
    reinforcement
    brace go with
    the lowered
    body, Darren?
    How did the rear
    spring tower
    reinforcement
    brace go with
    the lowered
    body, Darren?
    Yeah that is the primary reasons for not completely removing the body lift. I kept 20mm blocks to ensure that it would clear. Glad I did cause finding another 20mm under the bonnet would be impossible. I think I have enough in my IC to adjust to close the bonnet but another 20mm would smash me
  4. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    mudnut (22nd August 2015)
  5. #1153
    Wow you've been busy Darren! Nice work though mate and I'm sure you'll work it all out
  6. The Following User Says Thank You to Winnie For This Useful Post:
    MudRunnerTD (23rd August 2015)
  7. #1154
    So got back on the GQ this Arvo. Finished tightening all the body bolts and finalized the body lift reduction. Very pleased.
    Then the daunting. Lifted the bonnet and started on the intercooler.
    Out she comes
    Couldn't remember how to remove the heat shield...... Figured it out!
    Out with the 9" grinder for some slight adjustments!!
    Test fitted to intercooler back in and shot this vid with my iPhone in the engine bay. We are close! Very close!!
  8. #1155
    So with the body lift gone I am glad I drilled these holes for the top of the front shocks or they are never coming out!!!
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (24th August 2015)
  10. #1156
    193 Post(s)
    A lot of work Daz, getting there mate looking good . . . The bar work will be fun . . .
  11. The Following User Says Thank You to Rossco For This Useful Post:
    MudRunnerTD (24th August 2015)
  12. #1157
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Been busy!
    Are you spraying the guards yourself?
    Also I wonder if you could find some rubber bungs to in the shock tower holes, it might help keep dirt out out the engine bay?
    Hello from Under Down Under!
  13. The Following 3 Users Say Thank You to taslucas For This Useful Post:
    Bloodyaussie (24th August 2015), MudRunnerTD (24th August 2015), Winnie (24th August 2015)
  14. #1158
    Been busy!
    Yeah I reckon I could. I used a hole saw so it's a nice neat hole. Not sure how much would enter there versus the rest of the engine bay though? Will check it out though cheers.
  15. #1159
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    Your shock tower will hit the body, the top of my shocks punched holes in those humps without a body lift
  16. #1160
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by liftlid View Post
    Isn't that why there's a hole cut there?
