How did the rear
spring tower
reinforcement
brace go with
the lowered
body, Darren?
How did the rear
spring tower
reinforcement
brace go with
the lowered
body, Darren?
Yeah that is the primary reasons for not completely removing the body lift. I kept 20mm blocks to ensure that it would clear. Glad I did cause finding another 20mm under the bonnet would be impossible. I think I have enough in my IC to adjust to close the bonnet but another 20mm would smash me
mudnut (22nd August 2015)
Wow you've been busy Darren! Nice work though mate and I'm sure you'll work it all out
MudRunnerTD (23rd August 2015)
So got back on the GQ this Arvo. Finished tightening all the body bolts and finalized the body lift reduction. Very pleased.
Then the daunting. Lifted the bonnet and started on the intercooler.
Out she comes
Couldn't remember how to remove the heat shield...... Figured it out!
Out with the 9" grinder for some slight adjustments!!
Test fitted to intercooler back in and shot this vid with my iPhone in the engine bay. We are close! Very close!!
So with the body lift gone I am glad I drilled these holes for the top of the front shocks or they are never coming out!!!
BigRAWesty (24th August 2015)
A lot of work Daz, getting there mate looking good . . . The bar work will be fun . . .
MudRunnerTD (24th August 2015)
Been busy!
Are you spraying the guards yourself?
Also I wonder if you could find some rubber bungs to in the shock tower holes, it might help keep dirt out out the engine bay?
Hello from Under Down Under!
Bloodyaussie (24th August 2015), MudRunnerTD (24th August 2015), Winnie (24th August 2015)
Your shock tower will hit the body, the top of my shocks punched holes in those humps without a body lift
