Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Wireing up an Anderson plug
    Nov 2014
    Waikiki, WA
    Hi Paul, A fuse at each end will protect against this. Just at one end won’t.
    A range of fuses on ebay, just one example here;
    http://www.ebay.com.au/itm/320840775...%3AMEBIDX%3AIT
    2002 ST Coilcab, Chevy 6.5 V8 Garrett turbo, intercooled. 3.9 diffs, Cooper AT3 265/75/16.
    Trailstar Aquila 5.4
    http://s4.zetaboards.com/Gold_Detecting/index/
    http://www.youtube.com/watch?v=y7GCkFcHsh0
  2. #12
    Patrol Guru paulyg's Avatar
    Ballarat
    Thanks for all the great reply's,
    The camper has a dc to dc charger already in it, and the Anderson plug is fused,
    I will run some big cable on top of the chassis and a fuse near the second battery.
    2010 TB4.8, 5 speed auto TI Wagon, Beaudesert ceramic coated Extractors and 2 1/2 inch exhaust, 3inch lift, BP-51 shocks, Black hawk radius arms and drop boxes, Road Runner Offroad billet alloy draglink, Boss air bags, 295/70/17 KM3s, Redarc Gauges, GME XRS UHF, Autometre fuel gauge, Alpine head unit with offroad maps, Carbon winch, Opposite lock bull bar, Light Force Strikers, Safari Snorkel, Duel long range tanks, work in progress.
  3. #13
    If you have a DC/DC in the Camper then the feed cable does not need to be very big at all.
  4. #14
    Ballarat
    What size cable and fuse should I use?
  5. #15
    Quote Originally Posted by paulyg View Post
    What DC/DC charger do you have?
    If it is a 20 amp jobbie then a 30 amp fuse at the 2nd Battery Terminal into 10 AWG cable would be fine.
  6. #16
    Hardcore
    central coast nsw
    What about if he wants to solar charge back to aux battery, cable size then should be large enough to suit panel reg out-put and distance etc?
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  7. #17
    10 AWG will easily handle a couple of hundred watts of Solar Panel
  8. #18
    Ballarat
    I have a 30 amp dc to dc charger and a 255 watt solar panel.
  9. #19
    Go to 8 AWG.
    10 will handle the Solar easily but is a bit marginal for the max spec on the Charger as a 30 amp Charger will pull closer to 40 from the supply if it tops out.
  10. The Following User Says Thank You to the evil twin For This Useful Post:
    cgm (1st August 2015)
  11. #20
    Ballarat
    Thanks a lot.
