Ok need some ideas for my awning light and not led strip lights, I think it can be done better.
Im thinking 8 LED cree DRL with a dimmer., I saw BA had a led work light
shining sideways so any pics would be great, it will mounted where the eye nut is
Threedogs, any luck with your led light. I used to have one but it was portable, I had it attached to an right angle bracket and this just slotted into a raised piece of 25 x 3mm piece of ally flat that was screwed to the inside of my roof basket. Probably more importantly any more info on your spare wheel lifter?
I.ve decided on this 18 watt die cast alloy one from Kawell.
It has a 60 degree beam which Ill wire via a dimmer and remote control
about 200mm long
