18th July 2015, 11:41 AM
97-8 GU Transmission in Drive
Hi Guys, noticed when it's cold and when I put trans in Drive ,I find nothing is happening e.g. "not go forward" . then 10 to 15 seconds later it goes forward. after that the trans runs great , feeling strong and no slipping at all. when this happens when it's cold and can put trans in first gear and drive off normally, then back in to drive and runs fine. My ? is the ECU has a bug in it or fluid valve just about to go or something else. regards Alex
p.s. I have changed the auto fluid and filter about a month ago.
18th July 2015 11:41 AM
18th July 2015, 02:01 PM
What was it like before you changed the fluid and filter?
18th July 2015, 07:15 PM
4bye4
I was thinking along similar lines. If the fluid was really contaminated, it might be sticking valve(s) in the valve body.
Dismantling and cleaning a valve body is within the capability of anyone with mechanical skills.
I did a thread on it with pics..
John
18th July 2015, 11:07 PM
I actually noticed a noise in my auto after I did an oil change, changed it again to be sure. It was actually that my auto was already on the way out and needed a reco.
Not saying that yours does, but getting it looked at by a shop will be best in the long run.
I wanted mine to hold out for a few weeks as it was just before Xmas, it didn't and I destroyed the entire box. Cost double what it would of, had I gone sooner. Imo an auto playing silly buggers is not a happy camper, and is in need of some love.
1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me
19th July 2015, 08:17 AM
An auto on its way out would have a good amount of debris in the pan and that would have been noticed when the pan was dropped to do the filter.
John
19th July 2015, 10:38 AM
jff45
Mine didn't have a whole lot. Had a bit. But not in-excess. In saying that, the reason my auto died was due to the bearing in the torque converter failing allowing the fins?(plates? Whatever the things inside the tc are called) to wobble and then grind away at each other filling the cooling system with debris and super heating the box.
19th July 2015, 01:17 PM
lhurley
yeppers, that will do it..............
best case scenario is to take it to an Auto Tranny specialist
they will give you worst case is could be - and also costs involved to rectify
19th July 2015, 03:03 PM
Does the Power light on the mode switch flash to indicate any faults?
John
29th September 2015, 10:11 AM
jff45
Hi Guys, Sorry been oversea's ( USA) for the first time at 53 and love it . no fault lights , but the car still does it off and on . like this I can put it in second and drive off all fine then put it in drive down the road and it drive as it should , maybe a sticking valve !!!!!!!!! regards Alex
29th September 2015, 11:24 AM
Didn't someone mention possible sticking valve(s) in post #3 ?
John
