Hi guys, Ive recently bought a 1986 MK patrol with an l28 petrol engine. I changed the fuel filter next to the pump to try and solve an issue of the engine hunting while idling. She started so i put everything away. Later when i tried to start her, she wouldn't. I turned the engine over a bunch of times because i was in a hurry (which in retrospect may not have been the best idea). I figured it must be air in the line but i cant figure out how to bleed the fuel out. trawled forums and found nothing. I also tried spraying starter fluid straight into the carby but she still wouldnt start, wouldnt even hint at starting.
