Hi all. Have a uniden din size uhf. Having issues that when receiving incoming transmissions i get continuous static coming through. I can only stop the static by tapping my handset button. Any ideas?
Do you have a squelch button, may also be loose wire
Does have a squelch button which I've played with. No luck. Only seems to happen when close to the person traveling.
The 40 channel and 80 channel dont like talking to each other. Maybe thats it.
KATROL- The 2nd
GU TD42TGi
Silent member 1208
katwoman (17th June 2015)
It wont be the differance betwen the 40 / 80 channel rigs as long as they are on the same channel. (and between channels 1 - 40)
40 - channel reciveing a transmission from an 80 channel - the recived audio is lower
80 - channel reciveing a transmission from an 40 channel - the recived audio is higher, worst case you could get some audio blocking (bit of no audio). But most of the cbs are desiggned to prevent this.
How i it transmiting? do you have good range - can others hear you a km away? - as you might have a staffed antenna / cable / connector (most often a connector fault).
When you tap the button and stop the static, do you then hear ok?
Or are you activating the tranmitter?
katwoman (21st June 2015)
Do you have the unit connected to the cigarette live wire? If so, hook it up to your deep cycle battery directly. I use to have it this way and found that the accelerator / idling from motor was inteferring with the unit when listening. Just a thought.
