Hi all , Sprock here , new to site but has been very informative & excellent detailed descriptions for solving problems , my 2002 GU patrol wagon intermittently has engine light come on with varying levels of power loss , have checked & cleaned MAF sensor , earth straps , replaced 4 fuel filters - bought vehicle 3 months ago & it had been sitting in a garage for 18 mths so thought it may have had 'diesel jelly' in the tank , 1st filter was messy inside but last couple have been fine . I took the inspection plate off the floor in the wagon & removed the section on the tank with pick ups / gauge etc , noticed the 'bowl' that should be spot welded in the bottom is floating around as much as the spring loaded pickup will allow , has anyone else had this happen ? Whenever it plays up - if I fuel
It up the light goes out & its back to full power . I thought this bowl thing floating around might've been blocking the pickup but I see it doesn't pickup from the bottom but above the bottom disc thing. Sorry for the long winded post but I tried to be as detailed as I can.
