31st May 2015, 02:00 PM
Moderator
The Following 7 Users Say Thank You to MudRunnerTD For This Useful Post:
93patrol (31st May 2015), AB (31st May 2015), Bloodyaussie (31st May 2015), krbrooking (31st May 2015), threedogs (31st May 2015), Winnie (20th May 2019), Woof (31st May 2015)
31st May 2015 02:00 PM
31st May 2015, 02:06 PM
Good stuff Darren...... I guess you have to be good for something.... ha ha ha.
The Following User Says Thank You to Bloodyaussie For This Useful Post:
MudRunnerTD (31st May 2015)
31st May 2015, 02:07 PM
I take it from your other post that you need a 100mm flare?
once painted it will look a treat good stuff MR thanks for sharing
31st May 2015, 02:09 PM
Good work Darren. Looks like a lot of fun man. Nice write up as usual.
Live life, Love life.
Snatch straps on towballs can harm and/or kill!!!!!!
The Following User Says Thank You to krbrooking For This Useful Post:
31st May 2015, 02:18 PM
Travelling Podologist
How did you determine where the fold lines needed to be? Was it just a case of taking them out as far as possible whilst leaving some metal between the door in front & the fuel filler behind? Whatever, it looks the part.
Your previous comment about needing to make wider flares made me smile ..... I wondered “what for”. I can’t see them disguising your monster truck tyres from an eagle eyed plod! Ha ha. Or did you just want to keep the mud off you paintwork.
Oh & I noticed the grass has been cut!
31st May 2015, 02:23 PM
Not sure if i am looking at it right but did you actually cut any metal out of the guard or just fold the lip out then fold it all back in to the line you marked? Everyone i know just takes to the guard with the grinder and removes the extra metal. I have never seen it done that way!
31st May 2015, 02:32 PM
Moderator
Softy
Yeah sorry I didn't get a pic when there were 2 lines drawn. When I go the next one I will take a pic of that..
So once I drew the new line which becomes the fold line a drew a second line about 25mm down from that line. This become the cut line and the new tab to attach flares too.
You can kind of make out what has been cut in these couple of pics. Basically the old tab.
The problem with just cutting it all off you then need to face fix a flare or weld tabs back on. If your concerned you could add an extra few cross cuts to help accommodate the curve but it folds fairly easily.
Check out my Toy -->
Rogue Dung Beetle
31st May 2015, 02:41 PM
Moderator
Cuppa
Hi cuppa, I drew the line while the wheel was still on and just by eye. At both spots the panel is double thick and once cut separate and are the inner and outer, I treated them together and when i fit the flares will bolt back through both sheets .
Lol yeah I used shears to cut the long grass the mower missed when I took the wheels off.
Yeah the big flares are to convince my inner voice that I don't stand out like dogs balls and won't get pinned if I run flares that cover the wheels. Did I mention I Love Night driving
Rogue Dung Beetle
31st May 2015, 02:50 PM
Ahhh yep.... cheers I can see it now.
31st May 2015, 02:56 PM
Nice job Daz its getting there, should be able to drive it soonish ☺. Need to do the same to my fronts soon so i can get flaps back on and not rub.
I did notice nice job on the lawn too whilst the wheels 's were off.
The Following 2 Users Say Thank You to Rossco For This Useful Post:
AB (31st May 2015), MudRunnerTD (31st May 2015)
