Results 11 to 20 of 26
Thread: LPG System Removed to Space for Duel Battery and Long Range Tank
    Expert Agronaught's Avatar
    Sydney, NSW
    I've already got the 70l sub tank so a 95l would probably be ample for now. The LPG range has gone from bad to worse, and I refuse to spend more on it beyond ripping the bloody thing out.
    I've got a trip in June, then nothing till September so time to order all the bits I'll need.
    Cheers.
  2. #12
    Quote Originally Posted by Agronaught View Post
    Cheers.
    How bad are the figures?
  3. #13
    @ GUMAD IMHO I think you have done the right thing, OOI can you weigh what you have stripped out?.
    Should be interesting , These motors are not designed to run on gas, and valve recession is a big factor
    Gas burns way too hot I have plenty of melted carbies here from suffering a lean out.
    @ Argonaught even with a 75ltr and 95ltr you should get what 1000-1100 ks from a 4.5 or 4.8 on the hwy?
    not high country or Simmo
  4. #14
    Sydney, NSW
    800 city, 1k offroad of thereabouts. Depends on how many cruisers are in the party.
  5. #15
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Id kill for that. I get roughly 350km to 100 litres of LPG and 150km to 30 litres of petrol
    Lucus30's 1999 GU ST TB45E
  6. #16
    That's 95+70=165 LTS, of petrol, right, or is that gas+.70=?
    Quote Originally Posted by lucus30 View Post
    I'm about 100km more on gas and about the same on patrol.
    Runs ok on both fuels, petrol a little better
  7. #17
    Sep 2013
    16 Post(s)
    Probably because yours in injected. I suspect that would be the difference
  8. #18
    Wouldn't have thought that it would be that much if a difference.
    Anyone else running gas injected? Would like to know what your getting.
    Maybe your right foot is heavier that your left......
  9. #19
    Sep 2013
    16 Post(s)
    My right foot is not heavy ha ha. I guess it could also come down to the majority of its use is 4wding
  10. #20
    being injected would only give you a more efficient gas delivery system.
    So a tad more power, I think you should aim for 400ks out of 100 usable gas
    Something not right IMO if you're only getting 350, use "Y" pieces instead of "T" pieces , creates a
    better flow for the water and less cavitation
    http://www.ebay.com.au/itm/171419212...%3AMEBIDX%3AIT
